  • 7 months later...
Wow it's been a while since I've updated this thread
Let's see.... the car has been off the road for the last 6-7 months while I save and stock pile parts.
I've been driving an auto civic around..... yes a civic, please don't think bad of me :worship:
:P
So, now for the parts.
RB26 cam covers, also picked up the cam gear backing plate and a pair of -10 breathers
Oil catch can/washer bottle combo
  • Like 1
Its about time some updates got made! Haha.
Thats a Hi Octance can setup yeah? Very nice mate.
Also, pics of civic :P
Yeh HiOctane catch can
No pics of the civic, it's bad enough that I own it, don't want people to know what it looks like :P
The cam covers were sent to be painted earlier in the week, just waiting on the baffles for them
The car is due on the hoist hopefully monday. Drop the gearbox and pull out the old sump and install the new one.
Install everything else then work out what fittings I need and measure up lines
So keen to start the work.
After months of saving and stocking up parts it's time to get started
When I got to my mates places early yesterday morning and walked in to the garage to see this I was jumping around like a school girl. :D
I was finally able to get my hands dirty with this car
We dropped the gearbox, removed the clutch and flywheel and removed the old sump.
Couldn't belive what we had to take off to get to 2 small screws at the rear of the sump.
Also noticed that my passanger side engine mount is completely screwed so both mounts will be changed, Nismo mounts of course :P
We hit a bit of a snag late yesterday afternoon. After removing the timing belt, harmonic balancer then the oil pump, we found that the new billet gears I've got are to big for this pump.
It looks like they are for an N1 oil pump. So my mate was going today to get it swapped for the correct gears as well as pick up the new engine mounts.
So that's it so far. I'm back at work for the next 3 nights so I won't be able to get stuck in to the work until saturday afternoon/night but with my mate being on holidays, he'll be able to pump out a fair bit until them.
  • Like 1
Got a problem with the intake manifold though. On the stock runners it sits to far to the left and the throttle body hits the fuse box.
Not sure if there is a difference between the 33 and 34 manifold but something does seem right with this.
I'm going to have to head to plazmaman on monday before work
There is a different between 33 & 34 manifold - one of them is the the Idle Air valve. But if yours fit on the manifold then it means you've got the right one.
I was told you dont need to relocate anything to install these. Keen to see what the issue turns out to be.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
