You have to wonder - its quite a lot of effort to go to though! They do mention the flow/restriction issue (though potentially understate, or underestimate it) of having a divided turbine housing and an open manifold - so maybe it was just a case of the units being on hand to try out. Regardless of their reasoning or motivation I'd take it with a grain of salt :)
The HTA3794 and PT6766 have been tested "all in" on a properly built 2litre in the past and the PT6766 had slightly better spool, the HTA3794 made more power at every boost level until ~54psi where the gap closed - but the HTA3794 still had the edge by around 20whp from memory (at ~930whp!!!). The HTA Super94 is being tested and so far its meant to spool better than and make more power than both, I will definitely update the thread when that is made public.
I have heard some historical stories about that kind of thing, I wonder if they are trying to improve that image? They got Mat his turbo within a week and had a bit of reasonable input (I think?) and recently posted on their Facebook page that people could send requests regarding sponsorship based on a few requirements. They have also been seeking input and providing Q&A on the US EvolutionM forum. Hard to say though.
The housing options are just what is posted on the site, unlike Precision the universal FPs are mostly Garrett based which means you can essentially use off the shelf Garrett (or 3rd party) GT28/GT30/GT35/whatever turbine housings with them - they will probably also do hybrids or a preferred turbine housing per request. I would hope so, but I guess I can't speak for them - though seeing as they have made people HTA4094s, HTA3073s, HTA2868s etc I am guessing it is true.
I don't know what they have planned but it was a similar story with Precision, they had website that hadn't been touched since 2006 or so, seemed a few newer turbos with very little information and a team that didn't seem like it was going to expand. They really went back to the drawing board and stepped up their game to make them what they are today.
Although they seem to be a smaller scale company there's no reason why FP couldn't if they pumped some funds into some making their operation more efficient. They must have sold thousands of Red and Greens for EVO's!
just caught wind of this ridiculous result from Boostin Performance in the US, a FP68HTA bolt on turbo (so basically a high flow TD05 turbo using a compressor with the same size exducer as the stock 16G) making 501whp on E85 on Boostin's Mustang Dyno which is not a ultra happy dyno like most consider the US dynos to be. This is a crazy power level from a turbo this size on a Mustang dyno, no doubt the quality of the setup used has a lot to do with with it but it's pretty amazing nonetheless.
Check out the power band - I had mentioned that this compressor on a BB StageII T3 turbine would be an insane response alternative to the HKS GTRS guys which would be way better suited to an RB25 over the GTRS, I definitely do not take that back after seeing this:
Have seen that, it's one of the most flawed comparisons ever - it kind of sucks that people can put that kind of data out there to confuse research people may be doing.
Cmon now Lithium, you're smarter than this. You make yourself sound like a FP fanboy.
At least post your source from the dyno you just posted. who's providing poor data now?
Edited by black bnr32
At least post your source from the dyno you just posted. who's providing incomplete data now?
Well i think my dyno sheet was a pretty fair comparison dont you? Was 100% back to back... Lithium has researched these more than most and i am pretty sure i trust his data ;)
I wasn't accusing you of deliberately doing it - you may have not read the detail. I came to like the FP turbos after experiencing some myself, and reading lots of other peoples experiences and results from them... including the one you shared. I would say EXACTLY the same thing about if it were a Garrett, Borg Warner, Precision or whatever turbo if that happened and disregard the result altogether from that point (as I did there). Ignoring that result definitely does not make me a fanboy, you accusing me of being a fanboy for disregarding it says worse things about the subjectivity of your approach than mine... you must have gone to some effort to find a seemingly poor result for an HTA, and pulled one up that may as well have had a restrictor in the intake. If anything - that result frustrates me that good efforts were done with good turbos and part of the test makes the results all but worthless and would have been more interesting to have seen it done better and if it HAD been done more scientifically and shown results like that then I'd most definitely have taken it on board, and the odds are I'd not mention the HTA3794 with the fondness I do.
My source for the 68HTA (which I didn't post because it was on Facebook), but since you ask: https://www.facebook.com/photo.php?fbid=475658035842768&set=a.117337135008195.21587.115529075189001&type=1&theater
So the new Super94 HTA dyno testing results have been posted, initial driving impressions (that it was more responsive than the 6766 and 3794) don't match up with the dyno results - though the dyno results are still very impressive. This is with a .85a/r T3 turbine housing!
*UPDATE*
Tested the 3794 Vs. the new Super94 (FPXX94R), and the results are very promising. The Super94 made around 60 WHP more then the 3794 with minimal spool difference . With my setup, I never even noticed the extra lag but the extra power is very noticeable!! In my opinion, the Super94 almost makes the 3794 obsolete - 60 more WHJP without almost any noticeable spool difference.
Can't really beat that. {thumbup}
With this Super94 on the car I've gone 8.4 @ 177 MPH with a not so good 1.55 60 ft time. When I get the Red Demon back out, with a good 60 ft time I'm hoping to go low 8.20's or 8-teens. Also competed in a standing 1/2 mile event with the Super94 on the car. The Red Demon went 213 MPH which is within 4 mph of the world record (held by a 1800+ HP Lambo). It was tricky to get the car to hook up on the street radials, but I used boost by gear with lower boost levels in 1st and 2nd gear to get the job done. :mitsu: The car ended up running great on the radial tires.
"Like" our Facebook page to get the latest dyno/track results!!
Video of Devin's 177.49 mph pass - https://www.facebook.com/photo.php?v=628506815926
Video of Devin's 213+mph pass at the Chicago 1/2 Mile event - https://www.facebook.com/photo.php?v=629866980146
does it have a mad whistle to it when spooling up?
None at all compared to the GT3037-56T, it is ultra silent which is kind of what i needed as the boys in blue do not like noisy cars and you could hear the old whistle from miles away!
  • Like 1
Thats the one thing that makes me sad about that turbo... minimal antisurge whistle! it can be overlooked considering the results LOL.
Looks stunning in that engine bay tucked in there :)
Yes it can haha!
And thanks, pretty happy with the way it all looks! Got more to tidy up yet :D
Yeah i guess in a world where everything needs to be somewhat hidden, the less attention you draw the better.
Its pretty tidy now! I like the black stealthyness. My next move was a dark grey cam cover in matt. But when i decided to shift to Perth i gave up on any detailing and just enjoyed driving the thing.
FFP makes it look soooo much cleaner. Makes mine look tragic!
Bar the 4inch intake.. Stealthy little GT30 tucked away though.
Edited by gotRICE?
Correct, hence the black theme :) Car is now clean with no stickers or anything!
gotRICE I gather thats a Neo in an R33 ?
Damn I wish I'd known the differences in Neo and R33 heads and inlet manifolds before I got into porting and Tomeis .
A .
He's a tinny bastard and got one of the mutant late model R33s with strange bits on it haha
Anyone know of any low mount twin results? That would be very interesting!
Nope, though I personally wouldn't go for the HTA2868 twins that are available - I doubt the combination would match up overly well to an RB... especially when squeezed into those little housings. Owen Developments sell them though, and someone installed a pair on his GTR but then had an engine failure which set him back something fierce so not sure if or when that will be back together. It seems folly to me to try and push past the "-5s" flow at this stage in those housings, I guess the closest to a setup like that which I would like to see would be more like upgrading low mount T517Zs to use the 68HTA wheels, probably less likely to surge and generally be a better match.
    • haha don't worry I'm sue you've got more fun ahead buying a 30 year old turbo car....but at least you are in the right place to ask
    • some days eh? The keyless entry and interior light on/off with the key will be controlled by the Body Control Module, but I'm not certain where that is or what it looks like (you might get lucky with a search to get a part#, which could be printed on it). I'd start at the A pillar/ Under dash/kick panel on the driver's side
    • It might be hit and miss, but Nissan Genuine Parts and Pitworks are not the same thing, although both are available from Nissan Dealers with Nissan Part Numbers. Nissan Genuine Parts are the OEM stuff, Pitworks are their attempt to get people back from generic parts makers
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
