I am after people’s opinions and recommendations for head gasket, intake manifold gasket and exhaust manifold gasket.
They are to suit a RB25DET/RB30 build, the intake manifold is going to be a custom made one, and the exhaust manifold is a sinco custom.
I am thinking either a cometic or permaseal, or is there another option I should be looking at? I am keen to hear people’s experiences and thoughts.
https://www.sau.com.au/forums/topic/426736-gasket-recommendations/
I have a Tomei steel head gasket. the advantage is I have been able to remove the head and replace it twice using the same gasket. I see no reason why cheaper ones shouldn't be perfectly satisfactory though.
Yeah, the thick rubber gasket, i have the stock manifold and now im going to try a cosmetic gasket
It was fine with the small highflow at 18psi but the GTX3076 with 18psi and it leaked, then with a new OEM gasket it leaked again.
Edited by AngryRBGTX
More time to add to previous post
SAU Trader JDM Auto Link http://www.jdmautolink.com/p/nitto.html
Get good prices. Check the gasket kits out
I run JE/Nitto Pistons, Oil Pump, Drag Metal head & In/Ex Gaskets in my built 26
Overkill for my current power level, but I wont take the risk of another rebuild :no: and ready if I feel the need .....
Small investment compared to an engine rebuild. Not much compared to what your going to spend during your rebuild either.
OEM if your not chasing big power and running large boost
My engine builder built one of the first 1,000hp Rb26 engines in Aust many years ago using a OEM head gaskit with no issues.
I normally use Tomei but the builder insisted on OEM for his own reasons, 21 psi and 3 years later haven't had a problem.
if you think you're going to be pulling the engine back apart, use mls(multi layered steel) gaskets.
can be had in a couple of brands.
tomei
cometic
nitto
nismo
im using a cometic mls headgasket.
and I have now reused it after spinning bearings and needing a rebuild.
in saying that, im also using oem for the rest of the gaskets throughout.
if you want to support Australian business, go with nitto.
im pretty sure they are an Australian company.
and from what ive heard, they are very good with aftersales support.
either way, good luck with your build.
Only use a steel shim gasket if your having the block and head shaved so that it is flat. Be sure to spray the gasket both sides with 2 coats of hylomar when installing it. Otherise you'll end up with water in oil of vis-versa.
You can't beat an OEM gasket for seal of fluids. The OEM gasket will absorb 3 times the amount of surface variation of a shim gasket. If you combine this with o-ringing the cylinder block, head studs and a propper tune, it will handle all the boost you can throw at it.
Im using an OEM gasket, setup with extra crush on the fire ring (o-ring style) and am running 1.75kg/cm boost. I've had it up to 2kg/cm but have run out of fuel at around 5500 rpm. A problem soon to be resolved with a bigger fuel system.
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
