I've just spent all weekend trying to get my 02 sensor off with no luck...
I've used the special socket and it's on that tight that it's just stripping back the thread.. Tried WD40 to loosen it and even with a breaker bar and a 22mm socket it still won't budge!
What are my options? :P
  • 3 weeks later...
Replaced my O2 sensor with a nissan universal one from repco, worked ok for 1000km but then started bugging up. Was slightly hesitating at cruising speed then fuel economy went bad and finally engine light came on at cruising speed. My tuner said unplug the sensor and see if the problem is still there, so I did and that fixed it.
So now I'm going to have to replace it again. And this time it's going to be geniuine.
universal = :happy:
'93 HCR32 GTST OZA395-E2 $76.50ish from Bursons trade price, plug fits.
Just confirming for everyone, as this thread lacks R32 info. If a mod could add it to the first post in this thread it would be good.
I just had a look at mine this arvo quickly, been told the front one is playing up, but what did the stock RB26DETT come out with for R33? mine has o2 sensor at the rear with 3 wires, front one has only 2 wires coming from it?
which one has been changed previously? im guessing the one with 3 wires (i.e rear) has been replaced at some stage.
Now if going to buy one, are the front and rear ones the same on R33 gtr? or different part numbers?
on the R33 GTR, your o2 sensors should have 3 wires.
The one with 2 wires has been changed obviously to another type of sensor.
Front and rear are the same but with different connectors thus the different part numbers.
This link should help you : http://wardiz.over-blog.com/article-34295259.html
  • 3 weeks later...
  • 4 weeks later...
I replaced mine recently with a universal one from EL Falcon. Originally tried to solder wires but it's f**king impossible! It comes with a joiner though so i used that instead.
It's working pretty well, fuel economy is better (not sure by how much yet) but yeah see how long it lasts.
PS. Use anti-sieze on all exhaust bolts makes your like much easier getting them off later, thankfully whoever worked on my car did use it and it was piece of cake to get the old one out.
This is a good article on changing the O2 sensor on an R33 / R34 GTR. I've added it as a link to my GTaaargh O2 sensor page
If you find any part numbers that fit skylines or other useful links, let me know using the link at the bottom of my web page and I'll update the table. It saves trawling through 19 pages.
James
Here you have it NTK genuine nissan part $77 :)
* Nissan Skyline, R32 GTS-t
* Nissan Skyline, R32 GTS-4
* Nissan Skyline, R33 GTS25-t
http://www.kudosmotorsports.com/catalog/ng...25det-p-42.html
Edited by v8tzr
So the r32 rb20det and rb25det, came with two o2 sensors? one near the dump pipe? and one further down the exhaust, to quote the shop that tuned my car, they think my 02 sensor is lazy, so I suppose it's on the way out.
Hey guys,
I have apexi turbo timer with O2 sensor voltage reading feature. How do i know from voltage reading when my sensor are bad?
When i put the ign into ACC (engine isn't started yet), the display reads 0.2 V from O2 sensor. Is it normal? I have 3 inch cat exhaust on my RB20DET, I thought when engine is off, outside air would came inside and make the sensor reads rich near 1 V (a lot of oxygen). Any thoughts?
Thanks
  • 1 month later...
Damn, this is a sticky? Was looking for a replacement O2 sensor for a RB25DE..got to page 12! total confusion.
Guys the O2 sensor only controls EFI in closed loop mode..cruise or light throttle, anything else is determined by your map values and if it's OEM then rich is the key word..to save warranty claims, aftermarket..you need a tune. Sooo your not going to see huge increases in economy, unless you do a lot of highway driving. This means turbo or non-turbo doesn't make a difference as far as the O2 sensor is concerned.
Also like MAP sensors or ECU temp sensors, they are specific to each manufacturers specs, even though they operate in the same range ie. 0-1v NB O2 sensors..0-5v MAP sensors..you need a replacement that duplicates the same specs...
BTW the lower sensor doesn't have anything to do with EFI, it monitors CAT integrity in a narrow band above 1200degF.
Thanks Kudos..going to place an order.
Edited by FTO
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
