This one is mine at the top of the Black Spur after my first good run in it :-)
Hmmm - in retrospect - iphone pic doesnt really cut it - will head out with the EOS today me thinks.....
1452352_10152364240083275_1667777034_n.j
What size lift kit does that have in the front? :P
Took this photo at the RAAF base for the Big Boys Toys charity event for Legacy.
Edited by my partner in crime :)
That's a great shot! So jealous you were up close and personal with the Hornet as well :P
  • Like 1
Very nice Sean! :)
One weapon for impaling and...
Another for blunt force trauma...
Through the eyes of the naive!
1994 R32-GTR VSpec 2
Stock
18,000 genuine kms
Imported through Iron Chef in Oct 2013
Cheers
The Baron
Im Usually not envious of other poeples 32 due to the condition of mine. But yours is on a whole new level. I tip my hat to you. Bloody nice car.
  • Like 1
18,000 km's!
Would have been driven less then 1000 km's per year, on average...
I've got the full service history with the car - it did all of 800 kms between 2002 and 2012 - mostly to the 6 monthly service and back......
Not sure what the story is - but it has a little trickle charger attachment for the battery and must have just sat there for a decade......
I liken it to awakening Godzilla from the slumber under the ocean.... :-)
Cheers
The Baron
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
