Heh yeah just my 2c, always feel free to ignore we all like our cars different. I know it's a bit harder on a 32 with the battery there to have a nice catch can and route the breather pipes neatly around next to the plenum. Maybe relocate battery to boot if it doesn't cause roadworthy issues.
Edit: I think similar to this looks best, probably with black or braided hoses and I prefer the lines to run between the plenum and the strut tower so u can see the plenum nicely. Particularly when you have a sweet nismo item like yours!
Edited by Gts30t
  • Like 1
See, I don't know why anyone would do that to a bay.. Some nice braided or even black tubing doesn't cost the world, and cable ties look so tacky.. Obviously not priority one, but aesthetics!
  • Like 1
I think the 32/33 look great, I like the softer shape, it took me a while to really like my 34, the 34 are very busy with shapes all over the place.
and then the R35s aka 'mother cruise ships' came into existence and gave shape a new meaning
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
