OP's a phag.
Nawww seriously it's a very cool build Plattsy, you're going to have some serious fun in this thing :)
Lawl...
you know because I know you and have seen it all this thread is boring...but it will be interesting if it can crack 1:30 around sandown tho :P
yessssss.
needs more pics and details in future. you seem to know your way of the ghetto racing. evidence that it isnt just you calling favours on everyone :P
also, inb4 this build thread is the new wasteland and 50 pages long.
  • Like 1
no, but that is a k10 not k11....the bz11 is going fine.
interested that you are going to run a GTR turbo on it, that's what I was thinking too for the super-turbo. will be interesting to see how it goes. what is the capacity, 1300cc?
It's 1275 Duncan.
Only thing that hasn't been done by me is the manifold and I still helped out with grinding.
Itching to get more done.
All for this thread being wasteland ish.
I'll also get dave and scotty etc to take pics as we build and upload em!
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
