  • 3 weeks later...
You'll also find they aren't taking new customers, existing customers will be able to renew without an issue
Bummer! Was just telling Luke how awesome this policy sounds, back to the drawing board I guess!
Just ring back get someone else on the phone.
My first quote was 60 bucks higher than I'm now paying and what all others were too.
I knew something wasn't right, turns out she had me down as business use even tho I said private twice.
Shifty woman obviously paid on commission bases lol
  • Like 2
Unfortunately i went with just car (wallet is copping it lol) as no one else will insure me , not even shannons. Ill have to try and get a quote from NRMA and see if i can change over.
Still call David Snape for a better deal. If so, you have 7 (calendar) days to opt out of the new JC policy.
It could save you 100s that you can better spend elsewhere.
Ill give it a go but unfortunately i think im a little too late. oh well, money wasted. Lesson learned.
Thanks Terry. I gave them a call and Just car can cancel my policy so thats all good... I am on the phone to NRMA now and the only issue seems to be that i do not have a daily driver. So she has to enquire with an assessor as it is a case by case situation in regards to having a daily driver.
Being on hold sucks.
IF it is your primary car then they won't insure you.
Okay soooooooo. I misunderstood it as needing another vehicle insured with NRMA. They just wanted to make sure i have access to another vehicle for everyday use, which i do. I am 24 just if anyone is curious.
So final outcome was:
Agreed Value - 50k
Excess - $500
Premium - $840
Im honestly surprised how much cheaper it is. I was about to pay $2900 Premium and $1800 Excess. :/:/:/
Thanks for the help guys :)
  • Like 2
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
