4 hours ago, Birds said:
Get a lock up garage?
Insanity with an R34 GTR!! I assume you have off street or hidden parking at least?
I have a completely gated property but Shannons says because car is still visible from the street it's uninsurable for them
just insured my S15; surprisingly through VVC........though it's costing me more per year than my GTR valued at more than double the agreed value :-/
So i went on to say i'm guessing my GTR policy once up for renewal will skyrocket..................without confirming she did say that many things had changed in the last 6-12 months :down:
What's the latest in the best insurer for 34Rs?
My policy is up for renewal with Shannons, they want to drop the value on the policy to 72k, I think I would really struggle to replace it for that.
Premium is $1363 currently, but will go up if I get my way and we revalue the car a bit higher.
  • Sad 1
On 10/5/2017 at 8:08 PM, Birds said:
Same thing happened with club rego and RWC in Vic.
Some twits made their own car clubs just for cheap rego and no roadworthy / pink slip required, as it was up to the club to deem it roadworthy...started driving their highly modified and race cars on the road so the cops and Vicroads put a stop to it.
Yes, and in Qld too I'm afraid.
Ah well, Mercury is out of the picture now - unless they play phoenix
Last I heard from @GTR-N1 on facebook is that NRMA aren't taking any new policies currently as they're reviewing their policies. Is your car a V-Spec or Non V-Spec?
I had a go an shannons because when i tried to insure with them they effectively gave me a dick to the face.
25k, highest i could go with my mods was 30k. Wanted $2000 a year.
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
