I'm putting coilovers on my GTT and the bolt that goes on the bottom of them is wedged tight. I'm stuck on the right rear bolt. I've tried hitting spanner with a hammer, went through a can of WD-40 and even tried jacking up my ratchet to free it (rip ratchet). Does anyone have any tricks to free it? Also I can't heat it up because of rubber bushing. Any help would be GREATLY appreciated.
https://www.sau.com.au/forums/topic/449176-how-to-remove-this-fng-bolt/
You need a power bar - lucky you haven't stuffed your ratchet. Then you can slip a length of pipe over the handle of the power bar for more leverage. Can't see my car for reference atm but is there a nut on the other side you could try?
Also give the bolt a couple of good blows with a hammer to try to break the bond. Not so many that you deform the head.
Get some loctite freeze and release and spray it with that will help the get power bar with pipe and and you will get it off or easier option if you have a rattle gun.
Edited by boostn0199
Big breaker bars work to a point....then usually something breaks. If you work on cars you should really have a strong impact gun (not a cheapo). The impacting motion helps to break nuts loose more than just constant torque.
  • Like 1
There's a bit of metal in the way of the nut on the other side so I can't slip my spanner over it. I'll try the power bar and loctite freeze. Not too keen on buying a rattle gun as id blew the bank on coilovers but if that doesn't work I'll have to as the bolts starting to strip. Cheers for the help guys and I'll let you know how it goes.
I busted my ratchet doing it with the hydraulic jack haha. I finally got the rear bolts off using the bar but now I'm stuck on the front ones. There's not much space to use the bar between the rotors and fenders. Has anyone changed suspension before and if so could you tell me how you removed the front bolts ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
