Hi Like, .2L,? 2.6 t0 3.2 = .6L to help off boost ?
Paul has explained.
And bonnet off ftw!
Bonnet back on means it's an outside car now.
Mwuh ha ha ha ha ha ha ha ha ha ha ha ha!
Paul has explained.
And bonnet off ftw!
You blokes are damaged merchandise :)
We have all owned Gtrs for a number of years now and unfortunately most of the this isn't anything new for us
Well someone could have clubed me to death 14 weeks ago, I would have done it for all of you :)
this is new to me.
I don't have the funds to pay a workshop to build for me.
I really wish I did.
this is new to me.
Maybe you should open a shop, be nice to your customers, no bullshit about completion dates and bingo $$$$$$$$$$$$$$$$$$$$$
I did that, problem was keeping the work load constant enough to stay a float long term
When I started business I kept working for a bloke full time and did mine after work, did that for 7 years, 7 days a weeks and very long days.
Too many people think starting a business is easy and all you need is the money, starting is easy enough but keeping it going is the hard part. You need a skill, a willingness to work long hours and be in the area where most of your business comes from, helps to know people :) OH,A SHIT LOAD OF LUCK!
I struggled once I got it started, making money was easy enough, went to my head for a while. But I was not a businessman type and that also made it hard and easier to make bad decisions :(
Edited by Nismo 3.2ish
if i could, i would.
Unfortunately, haven't done anything engine reco course.
And many mechanics who open a shop have a pre existing customer base in the former of after work, work.
I don't really know anyone who wants work done.
My family live too far away.
Friends are all mechanics.
So, really narrows the field.
Yeah Luke
There is so much more to it , but it is great if you have the talent to do most of your own work, save a fortune and you get the satisfaction of a job well done :)
You hear a lot of blokes say if I had the money I would do this or that, money does not make it work , unfortunately :/
I think my my job would be very close to finished and in their best interest to get it done ASAP and get paid :)
The modifications and the ceramic coatings are done for the Turbo exhaust housing and down pipe and ready to go in . As I understand it from them, it is the last of the mods needed to put the final touches to the build and then a quick tune.
Apart from a pic of the clutch, the drivetrain was finished without another pic being taken while it was up and this gets my attention, being a skeptic :/
Out of all the builds I have seen on forums , this has to be the most boring, uninformative one I have ever seen, like "Wham Bam , thank you Mam" in slow motion.
I hope the the outcome is worth it . Paul, I will let you do a test drive after the final tune and you can let us know if the shit I went through was worth it ?
So I guess it is close, might have to go to driver training school as it has been a while :)
You're spose to be telling us if it was worth it. :D
haha, I will do that but I want someone that has had these cars for a while and SEEMS to know what he is talking about to give his opinion :)
Hows the brakes on this beast?
Backs have about 3500Klm on them, my mechanic up here just put new fronts on, cannot think of the name of them. He said they are pretty good cold and could even take a couple of quick laps but that would be about it.
As I will not be doing track, quality brakes will do the job until I see what I really want to do with the car.
Paul said to try Endless CC-RGs, once I am finished playing :)
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
