Things don't seem to be necessarily optimal, but I'm not expecting to see miraculous improvements in power - perhaps some improvement in power delivery if it turns out the intake cam proves to be excessively retarded in practice.
I also do not expect any real over all power improvements. What I have is plenty.
What I would like to know is, if you have your intake side retarded by 3 or 4 degrees and you advance it 3 or 4 degrees , there is 6 or 8 degrees difference, what would this do for the low end power gain at lower rpms.
Never heard of an external wastegate opening due to exhaust pressure tbh, I'd consider it a design issue if it did - by function definition they are meant to block any flow until the reference pressures met targets - especially if it had both ports utilised.
If he is bleeding off a 12-14lb spring and has a higher than expected exhaust manifold pressure at wot due to a restrictive rear then the gate will crack open, no question. This always happens in this scenario, not the first time and it won't be the last.
With a larger higher flowing rear there will be a lot less manifold pressure at the same boost pressure, even running a 1.15 AR at 30psi I would expect to see less manifold pressure due to the lack of back pressure.
Just curious, if it was getting valve float in the top end, would you/could you tune around it by dropping the boost and retarding the cams?
The dyno curve looks like it gets a wiggle on a touch, maybe not significant?
It won't be floating. I run the same cams, springs and retainers and have given my setup 30 psi.
Not sure how much more boost you want to pull out of it. It's dropping to 18 psi as is.
Theoretically yes but really this is usually the last thing you do after the rest of the set up is A OK.
I think he was more leading towards that being a possible reason its like it is.
How's the water Pete?
When is it booked in for the next tune?
Hi Mark, waters all good :)
Just waiting for some other work to be finished in the shop, not much use leaving it there until he can work on it , maybe another week or 2. Not just the tune to do and I can still use the car while I am waiting :)
I've got to say I would be pretty unhappy with that boost drop.
Kind of like getting married to a hot Virgin, and then being told you have to use a condom for the rest of your life......
Yeah a bit of bummer :(
I will still take the Virgin , condom and all :)
If it's the turbo selection that is causing these issues.... Everything else is irrelevant. See what the new tuner says.
Fairly narrow minded, all you can say is its the turbo. Its rated for over 700hp ffs, if there are no other restirictions it should acheive close to that.
Can u tell me why my engine with a .82 rear housing does not have this issue?
  • Like 1
I am starting to agree with the plausibility of his theory - I wouldn't go so far as to say that's the issue, but.
You have a .82 open housing, a .84 open housing is a different beast and in most cases I would expect it to be more comparable in to a .6x open housing which would make people shit themselves if it was said that someone was going to put on a 3.2 litre aiming for 400kw+ on petrol.
When I first heard about this I thought the hotside was going to be too small and that was before I learnt it was a small divided hotside on it, I've never thought about or had to deal with a bad turbo match like this causing excess back pressure - I like to think all the things I have been involved with have quite well matched turbos and as such exhaust manifold pressure has tended to be sane and never thought about the effect on the waste gate but the more I think about it the more it makes sense. Always nice to learn something :)
Hope your right :)
I spoke to the bloke at Precision Turbo and he said it "should" not loose more than 50HP with the 3.2 . With some blokes taking these turbos up to 740HP with varied sized motors ? ?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
