This is that Nuke Surge Tank going in, does not block access to the Attesa reserve or anything else, it is 3lt but compact enough :)
That's a good looking bit of kit Pete, looks similar in many ways to the Aftermarket Industries ones.
Jez was pretty impressed with it and it will be interesting to see how it performs :)
You're shitting us right ??
Yes, get a bit sick of some blokes wanting things to go tits up ( sometimes just a stir , all good :yes: ) because they do not like what you want from your car or feel what you want is unrealistic , shit, thats what we all try to do, get what we personally want from our cars , matters not what it is and you do not have to agree with what the next bloke wants or how many $$$$s he spends to get it :)
Shit I have seen some blokes have spent $200,000 on their car over some years and sell them for $85k ?
I have no idea if I will get exactly what I want but it is pretty close already :)
  • Like 2
I think you need to take it all into consideration, as in how this thread started and now the direction of which it is heading.
And did the head gasket really let go? I cant read sarcasm
haha , I know where the thread went, all over the place when the topic went tits up once I drove the car home and there were problems.
The posts had some opinions on the problems and went off topic while waiting for work to be carried out , bit of shit stiring, some smart arse comments but just a bit of fun :)
Then after a few attempts to retune it that did not work, I then waited 3 months to get the car in to get the problems sorted, another month to have the work done, then I thought it would be over but it was still not 100% .
The work was not finished as there were a couple of things I wanted done including a retune, to me the tune was not as it should be, I was lucky Mick came up and drove the car and agreed that there were some things that needed to be looked at.
The tune is aggressive with ignition , with slight detonation , running rich on idle and boost. Full boost is not until 4600rpm and power flat lines at 63000rpm @ 22psi. Am I happy with that, guess ?
But once the new work is completed, it will be looked at again , cam timing and tuned.
The good thing is this work will be paid for by the parts I sold from the old build before I bought the car :)
Edited by Nismo 3.2ish
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
