30 rear 32 front, it is what you have to run with these tyres to get even contact across the tread
We will see 100 pages one way or another dam it :rant: lol
Dont worry mate I enjoy the info while I am waiting for my job to be finished and Paul is back in action, all good :yes: :yes:
You seen GTRNUR's results in the build thread pete, seems relevent to your situation some what, a 6466 that was maxing out with 98 at around 380ish , but he's getting full boost much earlier than your 4000rpm goal ...
When did his get full boost, I will try to find it later but I do not mind maxing out under 380 kw and I am hoping for full boost under 4000rpm and think we will get it, but my expectations so far in the modifying world have been less than met, lol
Full boost at 4600rpm seems late and hopefully with the cams and cat tweaked, the 6boost manifold , a new tune???
28 psi was at 3300 I believe. That's a 6466 with a 1.00 rear.
I'm not sure about that as the dyno wasn't logging RPM. When it had the 18lb gate springs installed it would easily get to 18lb at around 3200.
To get some control though, I changed the setup to use twin port boost control with the gates and am using 10lb gate springs instead. This is bringing boost on a little slower, so probably 3500 to 20lb and I have no idea where it gets full boost as my eyes are on the road instead.
Pete's setup should be all on around 3500-3700 at most.
  • Like 1
20-22 was best results on my street tyres
Different tyres respond differently to different pressure, cause these things a 30 series they rely on tread grip as there is very little sidewall so no flex so I need to get even pressure across the tread for best traction, it also means they need heat to work and that is something I can not do in 4WD at the drag strip on a 10deg night :(
they are not the best thing for drag racing or standing starts but awsome for circiut use
yes, eyes on the road once it's on, no sightseeing , lol.
Had a bit of a look at those 6Boost Manifolds, seem like a nice unit.
Hard to find a lot of info, anyone used the 6boost or knows about them.
From what I can work out, it is the way the 6 pipes all come together and there is no real disruption of the exhaust flow ( not sure about the wording) :/
Thanks, I should have opened my PC as this laptop really is difficult at times searching on SAU, I cannot login directly or get PMs or Notifications ????
So it seems like everything, some think something is great and others think it is crap ,haha
It's to late now don't you think?
With some people liking it and others not are down to personal taste, whether they got a dodgy mani, application and a million other factors.
It is better than that Swiss cheese mani you had
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
