Suspense, we need our next installment
So do I, it seems forever since I bought the heap and hopefully I will have a Dyno to post tonight or tomorrow, might get a few laughs with the final installment :/
But I might CRY :unsure:
But the test comes when I am driving it home :)
The new Pod set up is not as pretty as the original but if it works better, it will have a CAI when finished :)
Sorry to not go back through 95 pages to find the photo... Did they go from single to the dual pods or the other way around? I'm presuming the single is the new setup? Much neater in my opinion if it is. Less clutter = good times!
  • Like 1
Went single as the other setup did not work with the new 6boost setup
Already looks cleaner and will look cleaner again once inclosed plus no AFM to restrict flow
Tell Jez no rush, we still 5 pages to go :P
4 1/2 to go and I am doing my best to drag it out, hope I never get the car and make it to 101 :cheers:
As you see I am doing my best to get the magic 100 :anyone:
I look forward to your response on the cars response, and also Jez's response on the response.
Ben your response has forced me to respond to your response!
As far as Jez's response he has not responded with a response but I am expecting a response from him at any time, well if he has time for the response as he said he is busy and may not respond to my response to his earlier response that got mixed up in all of the other responses that people responded to.
I hope you receive this response in time to respond to my response to your earlier response .
If you have time to respond I look forward to your response :cheers:
Fark this life is too short to respond, I think I will have a red and send you my response later on
  • Like 2
The new intake looks really nice and neat pete :yes:
Got used of the shinny intakes and pods and black tossed me at first, but it will have a pod cover anyway and I think it is a better position, so all good :)
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
