2 hours ago, GTRNUR said:
One more thing, my fuel temps dropped 15 degrees when I changed from constant pump speed to injector duty based PWM pump speed.  Well worth doing.
Interested in the impact that 15o has on fuel, I found no solid information last time I looked around.  What temp should fuel be, what happens as it gets hotter, and what is too hot?
1 hour ago, fatz said:
98 it doesn't seem to do shit
e85 she get hot and leans out a bit
small cooler fixed it in my r33
staged pumps also helps
The pumps were supposed to be staged to stop the fuel getting hot.
One of the first thing that was looked at when I first went to the shop , I was asked where the surge tank was and when I showed him, he said feel the surge tank and it was pretty hot
Does hot fuel interfere with the tune, could this be a reason it was spiking on 85. it was OK on 98 ?
Yea e85 doesn't like to get hot or it will lean out but you will be amazed how lean it can run before it melts a piston
98 even slight lean outs = melted pistons
I  logged it in my gtr and after three laps you can watch the afr getting scary
like I said a small cooler fixed it
I am sure your car cops heaps more than I will ever do with mine, Micko and Paul is another thing, lol
Going to do some laps with Paul after it is done and dusted, has to be better than dodging potholes :)
26 minutes ago, fatz said:
The irony of taking advice from 3 blokes who don't have running cars is not lost on me
lol
Hahahaha!
Now thats a bit harsh, lol
But the Pig is only a couple of months away now and it will be amazing !!!!
Micko just has to get off his BUTT, sorry Mick, I luv ya xxx
Why no closed loop correction in heavily load areas?
I set my closed loop all the way to 2 bar.
15 minutes ago, Mick_o said:
I think you know the answer to that! ?
2 bar I Don't party as hard as you blokes
I could have got some flash computer and talked about epic closed loop control..... or I could just install the 300 dollar cooler and be done with it back on track the following week
my car was back on track the following week
  • Like 1
That comment wasnt directed at you fat man. ?
In saying that your car is a filthy dirty track whore ?
Not everyones car is lol
Edited by Mick_o
Because edit
Haha all good mate love a stir. Damn SAU & its auto correct... Broad minded person lol... ?
Expected more shit to be slung big fella lol.... Off the piss or something? ?
Edited by Mick_o
Because edit
Controlling fuel pump speed with PWM ftw, imho.   Should be able to run MASSIVE pumps and have the fuel get no warming than with a stock fuel pump if you run the right amounts, you should be able to have headroom the whole way through so the regulator is still always busy but without nuking the fuel.
Definitely.
That is putting a lot of faith in that system.
It is, however you tune it so it's nearly 100% at the AFR you wish and then allow maximum of sat -/+5% correction either way.
I've been doing this for all the cars I've tuned for the track and "seems" successful, besides mine which exploded on the street lol.
Ideally fuel should be trimmed via baro, iat, and fuel temp but at times budget setups don't have the necessary sensors we all wish for.
Well finally after sorting out many problems they started to tune it up today and have a run on 98 at 20psi , next week they will turn it up a bit and fine tune it.
I will put the final tune results next week, here is the Dyno run on 20psi
Should look mad on E85
NISMO1 98RON 20psi 2.pdf
  • Like 2
After a long time and many negative and positive helpful hints and told to buy a V8 by a few , they said I would never be happy with the 34 , but I like the Skyline and just wanted this somewhat heavy 2.6Lt car to have some more torque to make it get going earlier.  a few pissed on me about going on about RESPONSE!. I was also told on the first page no one would be bothered to reply or read the thread , but 116 sometimes very boring pages later we are at an end , this will make many happy, but as I said at the getgo, don't like it, don't read it, piss off, many did, lol
The top end power has dropped down from the earlier tunes , 1st 475kw, then 461and now 457kw but it is more the car I wanted, response!
Micko has pick it up and bringing it up with Paul on the weekend, hope it makes it home in one piece and there goes my liver after a few days with these alcoholics  :yes:
  • Like 2
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
