2 hours ago, GTRNUR said:
One more thing, my fuel temps dropped 15 degrees when I changed from constant pump speed to injector duty based PWM pump speed.  Well worth doing.
Interested in the impact that 15o has on fuel, I found no solid information last time I looked around.  What temp should fuel be, what happens as it gets hotter, and what is too hot?
1 hour ago, fatz said:
98 it doesn't seem to do shit
e85 she get hot and leans out a bit
small cooler fixed it in my r33
staged pumps also helps
The pumps were supposed to be staged to stop the fuel getting hot.
One of the first thing that was looked at when I first went to the shop , I was asked where the surge tank was and when I showed him, he said feel the surge tank and it was pretty hot
Does hot fuel interfere with the tune, could this be a reason it was spiking on 85. it was OK on 98 ?
Yea e85 doesn't like to get hot or it will lean out but you will be amazed how lean it can run before it melts a piston
98 even slight lean outs = melted pistons
I  logged it in my gtr and after three laps you can watch the afr getting scary
like I said a small cooler fixed it
I am sure your car cops heaps more than I will ever do with mine, Micko and Paul is another thing, lol
Going to do some laps with Paul after it is done and dusted, has to be better than dodging potholes :)
26 minutes ago, fatz said:
The irony of taking advice from 3 blokes who don't have running cars is not lost on me
lol
Hahahaha!
Now thats a bit harsh, lol
But the Pig is only a couple of months away now and it will be amazing !!!!
Micko just has to get off his BUTT, sorry Mick, I luv ya xxx
Why no closed loop correction in heavily load areas?
I set my closed loop all the way to 2 bar.
15 minutes ago, Mick_o said:
I think you know the answer to that! ?
2 bar I Don't party as hard as you blokes
I could have got some flash computer and talked about epic closed loop control..... or I could just install the 300 dollar cooler and be done with it back on track the following week
my car was back on track the following week
  • Like 1
That comment wasnt directed at you fat man. ?
In saying that your car is a filthy dirty track whore ?
Not everyones car is lol
Edited by Mick_o
Because edit
Haha all good mate love a stir. Damn SAU & its auto correct... Broad minded person lol... ?
Expected more shit to be slung big fella lol.... Off the piss or something? ?
Edited by Mick_o
Because edit
Controlling fuel pump speed with PWM ftw, imho.   Should be able to run MASSIVE pumps and have the fuel get no warming than with a stock fuel pump if you run the right amounts, you should be able to have headroom the whole way through so the regulator is still always busy but without nuking the fuel.
Definitely.
That is putting a lot of faith in that system.
It is, however you tune it so it's nearly 100% at the AFR you wish and then allow maximum of sat -/+5% correction either way.
I've been doing this for all the cars I've tuned for the track and "seems" successful, besides mine which exploded on the street lol.
Ideally fuel should be trimmed via baro, iat, and fuel temp but at times budget setups don't have the necessary sensors we all wish for.
Well finally after sorting out many problems they started to tune it up today and have a run on 98 at 20psi , next week they will turn it up a bit and fine tune it.
I will put the final tune results next week, here is the Dyno run on 20psi
Should look mad on E85
NISMO1 98RON 20psi 2.pdf
  • Like 2
After a long time and many negative and positive helpful hints and told to buy a V8 by a few , they said I would never be happy with the 34 , but I like the Skyline and just wanted this somewhat heavy 2.6Lt car to have some more torque to make it get going earlier.  a few pissed on me about going on about RESPONSE!. I was also told on the first page no one would be bothered to reply or read the thread , but 116 sometimes very boring pages later we are at an end , this will make many happy, but as I said at the getgo, don't like it, don't read it, piss off, many did, lol
The top end power has dropped down from the earlier tunes , 1st 475kw, then 461and now 457kw but it is more the car I wanted, response!
Micko has pick it up and bringing it up with Paul on the weekend, hope it makes it home in one piece and there goes my liver after a few days with these alcoholics  :yes:
  • Like 2
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
