Guys........ As someone who monitors the sale of R32 GT-R's quite regularly, I am surprised to see their levels in such low numbers.
Currently at time of posting there are only 25 cars available around Australia on Carsales/Carpoint.
This includes all variants of the model (ADM's, N1's, Nismo, V-Spec 1 & 2's).
http://www.carpoint.com.au/all-cars/results.aspx?YearFromShort=1635&SearchAction=N&q=((((((Make%3d%5bNissan%5d%7b%26%7d(Model%3d%5bSkyline%5d%7b%26%7dBadge%3d%5bGT-R%5d))%7b%7c%7d(Make%3d%5bNissan%5d%7b%26%7d(Model%3d%5bSkyline%5d%7b%26%7dBadge%3d%5bGT-R+V-Spec%5d)))%7b%7c%7d(Make%3d%5bNissan%5d%7b%26%7d(Model%3d%5bSkyline%5d%7b%26%7dBadge%3d%5bGT-R+V-Spec+II%5d)))%26(((SiloType%3d%5bDealer+used+cars%5d%7cSiloType%3d%5bBrand+new+cars+in+stock%5d)%7cSiloType%3d%5bDemo+and+near+new+cars%5d)%7cSiloType%3d%5bPrivate+seller+cars%5d))%26Service%3d%5bCarsales%5d)%26Year%3drange%5b1980..1994%5d)&YearToShort=1665&sortby=Price
Only 4 cars are under $20,000 and one of those is $19,990.00.
On the other end, 10 cars are over $30,000.00.
To put things into perspective, on January 1 2012, there were 66. On January 1 this year there were 40.
The numbers consistently hovered around that level through 2013/14.
I also monitor the Japanese Auctions. Over 50% of the cars on offer are rated R. You get the occasional 3.5 very few 4's let alone anything above that.
I suspect we as Australians (private buyers and dealers) have little interest in bringing in cars rated 3 or lower.
As the Americans are now cranking up their demand buying anything in Japan built in 1989 and 1990 I can only see these numbers diminishing further.
I'd be keen on hearing from anyone looking for a car and there experience in finding one at the moment that meets their expectation.
Cheers,
Bob.
- Cause it's an older car, buyers want the best condition they can find.
- And with R Rated GTR's you have to question about it being road registered in AUS...
- I'd say so, their demands would be high cause they have waited so long before the R32's are road legal over there.
Check on gum tree, plenty of them on there and being sold for peanuts. I inspected 2 for people less then 6 months ago and they purchased them for 14k each!! One was an absolute gem of a car, the other was good but not great
There certainly are a lot of R32s being brought into the US now so I'm not surprised availability in Japan is getting scarcer. Pent-up demand was high no doubt because of the long wait and the Gran Turismo/Fast and the Furious crowd is hitting a time where they can afford these cars as well. In the four trips I made to my importer they pretty much sold another R32 to someone each time I was there. They had sold about 10 Nismos alone - no idea how many of the more common versions they must have sold. I know a guy who just privately imported a Nismo and a regular GT-R and sold them immediately. One of the writers on Jalopnik just got one himself so from all indications a staggering number of R32s are making their way Stateside.
That's also because carsales is failing for anything that isn't a new camry.
All the skylines are on gumtree now.
Most cars on gumtree are utter dirtboxes, if the owner can't even shell out $50 for an advert then what else haven't they shelled out for
  • Like 2
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
