5 hours ago, shubby0901 said:
Thoughts? I am not sure if I like the socket head.. also needs washers...
I think with some nice stainless washers it would look pretty good.
Or you could buy one of those "dress up kits" that have titanium style... but I prefer stainless myself.
Some fresh bling would look great i think. I agree with including some washers to hide that scummy ring though.
I'm pretty sure the lip is a separate piece they add to the standard bar. Never actually seen one removed though ?
I bought one of these for my R32:
https://zspecdesign.com/ultimate-dress-up-fastener-kit-for-nissan-skyline-gt-r-gtr-r32-r33-r34/
Chose the "gloss red" washers to match other custom elements of the engine bay. I think it looks pretty sharp without being too bling.
Rob
Currently I am making a list of all the required bolts....good thing I bought a thread gauge instead of assuming threads of bolts.
I think I will just go stainless steel bolts and washer. I dont mind that button head design, its just a matter of which bolts I change and which I leave....I am leaning towards just buying a bulk order of bolts and changing them out as I go around the engine bay and pull/replace parts..
Completed a coolant flush over a couple of days while I waited for parts to come in.
There are currently 2 majorish projects going on with the car, more to come very soon...hopefully....
Updates to the car:
1) Installed a cheap chinese Android Headunit
The system works..ok for the cost. I am still trying to set it up and giving different apps a go, I will check in again once I have it setup well...
This was easy to install. I bought a Nissan to ISO adapter from SuperCheap Auto, cut the ISO plugs off and wired in the headunit plug and voila, it works!
2) Installed big brakes ?
This was a project of mine which I wanted to do since I bought the car...my R33 now has R34-GTR Brembo Calipers, PMU Pads and Disks and GKTech Stainless Steel Braided lines, running Castrol Response DOT4 fluid.
Image may contain: car and outdoor
These were fairly more intrusive, but some tips if someone else is trying it out:
- Go to a proper fastners shop and gets bolts from there that fit, forget the old stuff that came with the calipers
- Get a nice expensive drillbit and some cutting fluid to drill your hubs
- Get an angle grinder or a reciprocating saw, this works just as well
- Make your own bleeder with some hose and a clear bottle, rather than the 1-man bleeders you can buy at auto-parts stores
Apologies for the average pictures, car needs a clean and a photoshoot with the new brakes....
  • Like 1
Question for fellow Skyliners - What are good intake setups that people use? I am looking for a good looking, well built setup which looks almost OEM. I have no intrest in having pods hanging around in the engine bay.  Is just the HKS performance filter a good enough upgrade?
There's some good looking pod shields out now and easy enough to paint/wrap whatever to make it look good. But from memory, your not running big power so the stock box should be up to the task with a god quality panel filter. Depends how much whistle you want ;)
OEM with filter.
11 hours ago, trel said:
Standard airbox with high performance panel filter all the way.
If you're on a stock sized turbo, trying to get a 4" inlet to line up with the stock airbox isn't fun (ask me how I know) haha
Post pics, then, with a small amount of plagiarism, the task isn't as hard.
Just now, mlr said:
That looks neat.
How did it flow?
No idea, decided I didn't like it so changed to a 4" intake before I tuned the car. Ended up with 323kW... then got bored, moved the gate from the housing to the exhaust manifold, made 372kW, then about 5 track days later it went bang lol.
  • Haha 1
  • 3 weeks later...
Some small but highly effective work done on the car today, got some small door dings fixed!
You can see the before and after. If anyone is looking for a paint-less dent repairer, Dentech Paintless Dent Repairer in South Australia is highly recommended!
  • 1 year later...
Its been a long time....since I posted here...not sure if anyone's still reading but hey, why not write what I do.
A new battery is installed, the car has been driven and will be driven for a couple of days....get the joints moving again....
Order some small parts....and let's get this car going again!
  • Like 2
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
    • Not yet quite as bad as what we've seen a Jim Berry clutch do in an R32 GTR though when it decided to cut a chassis rail in half... Still very very gnarly and a great reason to avoid.
