On 23/02/2021 at 9:17 AM, Dose Pipe Sutututu said:
works fine with a lift pump
As long as the stupid 5/16" inlet / outlet hardpipes are removed, as this really is the entire problem with the factory GTR top hats.
  • Like 1
They’re gone, is -8 now
Yeah I saw. 👍 These factory 5/16" OD hard lines have cost me 3 x cracked fuel tanks from pressurisation with a surge tank setup. Not to mention never, ever use the R32 fuel pump cradle return line to put fuel back at the pump - it goes to about 4mm.
Bin it.
  • Sad 1
Yesterday I finished work early and decided to play with the car for a little bit, was just going to drain the oil and water and pull the gear stick out, next thing I knew the gear box was on the ground (well on my arm which was on the ground) and most of the engine was undone B95609D8-9DA1-4F96-81AD-B862782ADBE2.thumb.jpeg.7013e83eca463371f29998f20f5ff3ca.jpeg259C7551-5656-4717-8527-243EB4CF373E.thumb.jpeg.059d269ca284ce309c4736c23b70b931.jpeg
  • Like 2
Last night I wasn’t sure if I had done some serious damage to my arm or not, I woke up this morning at it was still sore but still able to move it so guess it’s ok.
today i decided to take an rdo cause I was super keen on getting work done on the car, I pulled the clutch off, pull the front shafts and undid the mounts and pulled it out and threw it on a stand 124A8802-A101-4A19-A112-EC2F017459EC.thumb.jpeg.67936a22a6314fbcda169e8fb85be538.jpegthat engine bay is a mess, I plan on fixing that while the engine is out
E2C7C9A2-AB33-4A0F-8A4A-91FA8A398835.thumb.jpeg.b74db927199892550ff30ed65f1d0db6.jpegReady to start stripping it down
  • Like 4
Started pulling the engine down today and everything looks clean without any sludge and etc, got the head off and after you turned the gasket over you could see the gasket had blown between 6 and the exhaust side water gallery.
Unfortunately that turned out to be the least of my problems and so far I’ve found 3 cracks in the deck of the block between 2 of the head bolt holes and water jackets so it’s a bin job and the search begins 😞91C7C94F-328C-4A38-9F9B-6EFE092FAD51.thumb.jpeg.7371cc8cf57351daf9a64443458984bc.jpeg42C3225D-5A21-4245-A784-E2CD38E68CAC.thumb.jpeg.8ffd7ac1039faf86f3f28a049f8a5893.jpeg
  • Confused 1
  • Sad 3
1 hour ago, Dose Pipe Sutututu said:
You want a RB25DET NEO AWD bottom end? has CP pistons in it and Manly rods, ARP mains, ACL race dis dat.
Apparently Hermit at PRP reckons its strong.
Herd some of those 23u rb25 blocks are bettter then 26 blocks in terms of strength and thickness etc
Has it been bored?
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
