On 13/07/2021 at 5:20 AM, r32-25t said:
Ok I’ll have to have another look, when I was looking the picture shown was always the non abs version
Nismo direct pictures generally have seemed correct but forget the pictures. Find what you need through NIssan fast and then find Nismo heritage replacement part number.
I checked their site again and they only have 3 of the 5 lines for the abs version
Which ones can't you find or want ? If they're not in Nismo, it means they could still be available as a Nissan part possibly, as the Attesa rear hoses are like that - 3 are Nismo parts and 1 is still a Nissan part just to confuse things more.
Did a bit of running around today, first I picked up the engine covers
I had the powder coat removed and am going to have them painted after I decide on a colour
then off to rams to pick the head up
 661A3A28-3767-4102-AFC5-BA89B7C7394B.thumb.jpeg.ca6e962fad4c5582181e0873f8af24b1.jpegE89CE9AF-B9B5-4124-B6D8-5BA897F88EFC.thumb.jpeg.8027395fa34916f3bf11f7ff4e9a9c01.jpeg
all ported and the chambers opened up and all the good bits fitted and valve clearances set
also because I was told the Jun cams had to much lift and duration rams supplied some new cams for me
 Only kidding 😝
  • Like 2
On 21/07/2021 at 1:22 AM, 6BANGER said:
I would to ask a few questions about this os88 issue . Did you end up fixing the oil spitting out of the breather hose issues?
I chucked the toys out of the cot and sold it. There was two very different oil levels that I was told to run.
Aside from that, the OS88 is a very “dumb” gearbox. It has no gear position sensor, it only has a switch for the gear position display. It doesn’t come with a strain gauge and somehow they want to charge $23k for a brand new one. 👀. I have also seen a few bust with sub 500 kw too so I would take the 1500 Hp claim with a grain of salt. The length of the throw to change gears feels very long once you add a strain gauge. As a comparison, the ppg feels about half the distance.
Put the PPG in the car and haven’t looked back. I would not recommend the OS88 with the amount of other options around today even if you did find one for a discounted price.
  • Like 1
Pulled the old engine apart today because I need the oil squirters out of it for the new engine 90EFB439-88EC-48F0-9511-FA97A0EE9393.thumb.jpeg.1f9880bf8b368abd0c64e0960f65da15.jpeg
looks like I pulled the engine out just at the right time because they were ready to knock and start damaging things
  • Like 1
Always nice to pull the engine apart just before it gets expensive, instead of just after...I had the same luck in my recent stagea rebuild, it was ready to spin at least 1 big end too.
How old was the engine, and did you have any sign of oil pressure trouble?
  • Like 1
It’s a 33 engine that had never been rebuilt so at least 23yrs old, yeah I had the engine protection kept tripping because oil pressure dropping until I put the big sump on it
those were by far the worst of the lot but all of the bearings showed signs of issues, luckily the crank is still perfect and should be able to sell it
I wouldn't recommend a PPG or having to deal with them to my worst enemy :(
Are you not running a Pfitzner sequential, or have I missed something?
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
