7 hours ago, robbo_rb180 said:
What ended up being the issue?
New shed? How big ?
Something to do with one of the sleeves, haven’t been told exactly what yet, hopefully will find out when I pick it up and get the chance to talk to the them face to face
yeah new shed, it’s only a 6x6.5 but for a suburban area is a pretty decent size
  • 1 month later...
On 12/17/2023 at 10:22 AM, Duncan said:
Yeah 6x6.5 is pretty decent workspace as long as there is only 1 car in it, it's so nice to have space to work
I have come to find my 9x6.5 isn't big enough...
Too many toys (tools)... I think it's time to wall in the car port bay and move some stuff... Hmm...
Brett, update?
How's garage build?
Engine rebuild?
Isn’t really much to update,
the shed I’ve been trying to get the slab down but the certifier keep finding hoops for me to jump through, I’m hoping I’m somewhere near close now.
the car I haven’t seen since November, the engine isn’t back yet and either is the sump. I’ve already written off gtr fest and am starting to doubt I’ll make any other event this year
  • Sad 1
Ok it amazing how much things can change in the space of 2 days.
the shed is at the point where all I need to do is organize the concreter to do his thing and it’s off and running
with the engine
  • Like 3
with the engine
Awesome!
So.....  Have they given you the FULL story as to what it was?  Warped sleeve, cocked sleeve, cracked, driver error 🤪...??
1 hour ago, Shoota_77 said:
Awesome!
All I could get was it was leaking and they resealed it.
39 minutes ago, admS15 said:
Is it back in yet? Chop chop😉
I don’t have the car or the sump, my aim is to get my shed built and then get the car in there and start working on it again
  • Like 1
  • 3 weeks later...
  • 4 weeks later...
I decided to rebuild the throttle bodies because they didn’t feel smooth when you opened and closed them
them when I started
IMG_0269.thumb.jpeg.bc2200a5de997acc2e2cacda6bf30448.jpegIMG_0270.thumb.jpeg.6e96a8c64b75353ff9be9f6b261d18a3.jpeg
bit of heat to break the seal on the screws
press out the shaft
new bearings next to the old ones
IMG_0273.thumb.jpeg.605a6f300310d401592df60f57c8249d.jpegIMG_0274.thumb.jpeg.9215a330804ac81ae03e69777d0b3eb7.jpeg
cleaning the old throttle coat off the housing and butterfly’s
all clean
IMG_0276.thumb.jpeg.e4fe50ef0e6536ad04a13dba039ae5c2.jpegIMG_0277.thumb.jpeg.f98ab995dcb1e185cd654ea8ea3ce66e.jpeg
new bearing and the bearing locks which also hold the seals in place
IMG_0278.thumb.jpeg.e39f6bd8fcb89da12dec0e890cad892c.jpegIMG_0279.thumb.jpeg.3fe3a226c50f0081053ded9dd7251577.jpeg
new throttle coat applied and the new seals that I pressed in
once it was all done the throttle felt a lot smoother to open and close and definitely a much better piece of mind
  • Like 6
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
