Because everyone is too f**king scared to say what they're actually thinking when it comes to shit like this. No one wants to step up and say what everyone is thinking (except Sam Newman on the Goodes issue)
But another example is the Harly Bennel drugs story....
He has to come out and say he has a drug problem, that his life is out of control etc, he did a few lines of coke with some strippers.. If it wasn't for the pictures of it happening, he would've kept playing footy week in week out, but instead he has to put on a sad face for the cameras..
I know first hand that a current captain of an AFL club doesn't mind the coke, but because there's no photos of it out there he can just get on with playing football. One photo, and all of a sudden he has a drug problem and needs Jesus
  • Like 1
I can't understand why the media perpetuate the 'racism' theory
Because playing into it means they get interviews with the flog and can continue the storm in a tea cup and have something to write about. Fkn playground issue. Goodes needs to see that he took it too far and played a game he can't win. You never take on the crowd as a sports star, and to play the racism card is begging for reaction.
  • Like 1
Hey Hamish.... Remember your old car?
Turns out you weren't using it right... Need to put it into Snow Mode and just thrash it harder than Bird's mum
https://www.youtube.com/watch?v=hbo_GaP4KWo
lel
Then get spanked by Birds and his D1Rs
1-1
Until next time...
  • Like 1
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
