best part about calling ash re: work
ash: hello?
me: whats going on you f**king cock sucker
always wanted to abuse a customer.
wow how un professions they are a customer after all, it should be MR f$cking cock sucker
  • Like 2
So they didn't DOUBLE the stated quote without informing you first? Interesting..
He jacked my quote up by around double because he 'had two guys working on it'
Centerline sure seem popular..
See, you only hear the good becaues this forum is a f**kin joke
  • Like 1
Sounds like he doesn't realise that Double the man power = half the time = same chargable hours... lol
I replaced all the brake lines in the engine bay... Go to fill and bleed the lines and fluid starts pissing out of one of the caliper banjo bolts because the thread on the caliper is f**ked
Greglinesaustralia
I prefer brown Schweppes myself
Right now I've got Kirks in a can, which I'm sure is a pink one...but I think the can is making it taste amazing, along with the fact it's icy cold.
Best I've had was A&W (American brand) in a can. That was like vanilla essence in drinkable form.
  • Like 1
Staged by anti gun people, as suggested by pro gun people?
I saw the footage before I heard any conspiracy theories, and it didn't look right... He shoots her like 3 times at point blank range with a glock and she just turns around and runs off.. Then there's the father and boyfriend on fox news the same day their daughter /Mrs was murdered, on live TV no less, and not a tear is shed in an 11 minute interview. Instead they've both, already, dedicated their lives to gun control.. Their answers seemed pretty scripted
There's more theories about the shooting footage itself, gunman appearing to be white, wearing a different shirt etc but I haven't looked into that as I only came across this stuff last night and went to bed..
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
