Always had iPhones.. now have s6 edge, meh both do what I want from them the thing I like about the s6 is purely not having to use itunes to import music etc.
Oh and dat screen doe
+ 1
Hated itunes and importing. Main reason i use Andriod
Now i just copy pasta
itunes is aids
Never had an issue playing any song on my s3/s4/s5
but I'm not a hipster so I just download standard formats..
Of shithouse Comercial rap
If you were awesome like me you would have more trouble finding stuff
I get around spotify's premium account by adding only singles, going to my music and selecting the individual album or artist and clicking shuffle - 90% of the time it plays that specific song. Sometimes I have to use precious skips.
new propsed metro train stations: https://urban.melbourne/transport/2015/10/29/melbourne-metro-rail-stations-more-detail-released-comment
they seem like a really good idea. not sure how easy to dig under all that though... but i guess thats someones job.
english channel is just water and sand/mud.
under the CBD/St Kilda has all sorts of weird relics and unconfirmed assets. i dont know how deep the trains would go, may be deep enough to be clear of everything though.
and its not like we have the same calibre of individuals like the poms did with their metro.
Which is precisely why it was such a challanging build.
There were multiple layers which were far from straight, with only 1 type permitting the tunneling hence it had to move up and down many times. Added to this were centuries old buildings that were resting on said soft surfaces, as well as subway stations.
what you have a boner for the english or something?
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
