So shall we guess birds pi track times?
I'm guessing stock manual Toyota 86 2.05
Any further guesses?
As a comparison my first go was a 1.57 Zorst pod and a little boost, lowered springs so no castor camber adjustment...
No tune so 160ish
Got my goal of a sub 2 minute time...
How the hell do you get a 1:57 on a stock S14, and I'm 2 seconds off that with 230km/h down the main straight and AD08R and dialed in suspension?
Oh yeah, I need to learn how to drive now. :(
So while Birds and I were busy flying the SAU flag at Phillip Island, we totally missed that Alex revealed himself again to be a total f**king moron ?
Thanks again for your help with the engine troubles - she ran pretty happy for the trip home.
Jase and I noticed a blown turbo gasket too, so that was the high pitched squeal I was hearing when coming on boost. Driving on the street it now sounds like I have an ex gate :rofl:
Nice work. Yeah sub 2min is friggin solid effort. Lots of late braking and solid corner speed...
Oh yeah, my 2min 20+ was with no clutch. :P
Barnaby Joyce, while speaking to a room of ESL Chinese delegates decides to use a "battered sav" as a euphemism for low quality product.
What do we pay these idiots for again?
It gets better... clearly these people didn't know what a battered sav is, so he explains it as being part of the Australian diet. Realising he has now said the Australian diet consists of "low quality product" he back pedals by saying it's only given to people if they have bad parents.
LOL
Another English-thing the Aussies like, and known colloquially by Aussies as “savs,” saveloys are a seasoned hot dog-like sausage. They are boiled and served in a slice of bread or in a bread roll with tomato sauce. A “battered sav” is a battered saveloy which has been battered, deep fried and served with tomato sauce.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
