this has me surprised, they diluted their value.
yet ended up higher.
I expect this to drop down a bit.
that said if it drops under .035 which seems to be it's real value currently i'm then going to buy in, then ignore it for a year or 2.
What are you basing 0.035 on?
The reason it went up is likely because the capital raising was offered to institutional investors instead of dickwad short termers trying to make a quick buck. Private investors are therefore only left with the news that it was oversubscribed and raised 25 million instead of 15 million. Shows big confidence in the company from the sophisticated investors. The shares are diluted but even diluted the shares are fundamentally worth a lot more now because the company is in a better position financially. Company now has more than enough cash in bank to finish buying acreage, pay for seismic photography and get on with drilling ice wine 2 first quarter 2017. Unless bad news hits the price should not fall. May stabilise or slowly sink with no news, but with no news also come more long term holders and less short termers.
It may go down after the issue date when the shares are released to market, as institutional investors can still offload cheap shares for quick profit if they want but less likely to happen than with retail investors.
Regardless, not really share you should focus too much on the short term price of IMO. If you're watching daily for a good exit or entry point of a long term investment, half a cent or two isn't much in the scheme of things for a spec where one day the share will either be worth nothing or up in the dollars when the play has been totally proven up.
DYOR but I will continue buying up with this one. I still believe it is seriously undervalued given the potential prize on hand. You might want to look at the options too for a long term strategy.
In other news, Leesh's GTST nicked from the airport long term carpark :(
Think it was taken early April while we were away, so no doubt already in a thousand pieces, but just in case...black with a purple pearl, body kit and gold wheels.
Basing .035 on the recent new share release. That's what they offered the big boys so this what I base my roving off
Re car that sucks massively they had a no theft rate for decades till the new ppl came in and only cared about profits
Hope they find some footage. But also not holding my breath on them helping
so 2 now been in 2 accidents with buses in past week.
not looking forward to 3 times a charm..
(bus last weekend on way to a wedding tried to do a u turn and hit a tree, smashing windscreen and the bit above the windscreen/roof..)
(taxi on way to office this morning pulled out in front of a bus and got clipped by it.)
Woo
I really need to fit a fire extinguisher.... Maybe if I cable tie it to the front table it'll pass[emoji14]
Also need a diff. Finding time to drive to scottys while Scotty is actually home/available is always difficult.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
