Both of you cherry picking... wouldn't expect any less from mexicans.
Down 10% for the day.... Flying
if you're looking for a longer term play that 800k may be worth buying into the dip first up, otherwise keep it in your back pocket.
You should note that just after I posted this it dipped to 3.1c before bouncing to 4.0 and settling in around 3.5...lets see what the hour of power holds.
Wouldn't take any advice from jas bloke said stay out of property 6 years ago... That was wisdom worth sharing [emoji23]
I did sell out then.
Doesn't mean I stayed out.
That's suggesting we didn't.
I've been in and out of the market a few times since.
Few hundred K been made.
How much you made on 88E Birds?
Must be closing in on a dollar by now
Made a few cents last week but I had to pay CGT on them. My f**king nephew bought a controlling stake in the company!
you have not separated the home network to a General access and a internal?
Set up a pair of routers give her wifi to the external one and your on the internal with the NAS/important systems?
thought you were a sys admin.
on that note decided to do my CISSP any one recommend some decent training companies for it?
Lol can't do VLANs with my home hardware and couldn't really be stuffed.. she needs access to the NAS for her downloads too anyway :P
Plus she uses my HTPC to do it all anyways
Don't know much about who does CISSP but CBTnuggets were good for the cisco stuff I did
Trends suggest mohsen will sell them at a stupidly low price, which is great for Greg, however trends also suggest they will spontaneously combust once in Greg's posession... which is not so great for Greg
Thus SAU equilibrium is maintained, otherwise me dealing directly with Moh would result in luck and bad decisions dividing themselves by zero
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
