21 hours ago, Kinkstaah said:
Actually I didn't have issues... then I HAD issues after taking my suspension to a very well known shop that isn't Centreline...
......so, looking for someone who actually knows Bilsteins.
What did you have them do to the Bilsteins? and what are the issues you are now experiencing?
"A workshop" (Not Centerline, as in actually NOT centreline)
I wrote my car off as most know.
Bought new car, cool
Moved perfectly working suspension from old car, to new car at aforementioned workshop. They weren't damaged or affected in the accident in any way.
Get car back, front is mysteriously low. Like, super not right.
Take them back, ask to adjust height this time and not have a 45mm rake which didn't exist on the previous car. Front was like 325mm center to guard, rear was like 365 center to guard.
Specified heights on old car was 355/345.
Anyway, was told the fronts were maxxed out.
Then was told they were "able to be fitted because dis-assembled/re-assembled" and heights are good now.
But they were fine before, in the same model of car.
After that, the fronts are crashy as, they will slam into bump stops over speed bumps, as though the shock has nearly no dampening at all... though the height is right.
Also knock, creak, etc.
Never really got a reason why this occurred. Just a lot of handwaving when pressed for any details.
Hence wanting to go elsewhere for a 2nd opinion on the shocks by someone who will know Bilsteins back to front. Was planning to go to Quadrant for this, but have had other car issues in the meantime :P
started trying to finish off the last few little (but time consuming) bits on the pulsar. When fitting new fuel lines in the tank and the shitty plastic hose fitting for the return line snaps off. it has completely sapped all motivation I have. $91 from Nissan to replace the section of the inner-tank swirl pot thingy.
If anyone wants to come to my house and complete the checklist I have for the car, I will pay monies. theyre not little jobs you can just get a workshop to do, they will laugh at you, then do a shit job, then charge through the ass and take a month to do it.
ok for real estate gurus.
lets say you own an apartment.
body corp finds a prob with the building and lets every-one know they are due for a XX,000 bill.
if you sell prior to them sending you the actual bill do you need to declare this to the new buyer?
could this bite you after settlement.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
    • It sounds like you want what the Toyota Landcruisers have for their roof racks. Wanna know what you end up with? Rust holes in the roof, and water everywhere...
    • Discovered today that if I select reverse first and take my foot off the brake, then select drive, the drive indicator light works and so does the tiptronic gear indicator.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Does anyone here have any ideas?   Cheers guys
