2 minutes ago, UNR33L said:
what is laid up cover what happens if you crash it on the road?
1k seems steep if it's just garage cover.. why not just get 3rd party fire and theft?
hell my fpv is like 1k for full comp at market value
I think I'm covered for very limited use, but it's mostly for cars that aren't driven. Thought it would be a good idea while it's being built and then I'll switch to full comp once on the road.
Problem with third fire and theft is Just Cars will only do up to $10k value (it's still $400 with a $900+ excess) and you're not covered for someone damaging or vandalizing your car I don't think.
Wish you could just insure yourself as a driver and not your vehicles.
Ah righto - fair enough.
Car question, got quoted $300 by a shop to fit up some new front brakes, (calipers / rotors) they are supplying the brake fluid and reckons he needs the car for 2.5 hours. Sound about right? Was referred by a friend so assuming he'd half look after me.
Yes I know I could put them on myself but don't have the right tools for the job.
Could buy the right tools for $300
/weakexcuse
Just cars is $625 excess for fire and theft
I know cos I paid it a few months ago
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
