i got southland carwash to steam clean my now-gone pulsar a while ago. Seats turned out good, but they sprayed the entire interior (radio and everything) with some shitty washing product that stayed sticky. I had re-go over everything with a damp cloth to get the stickiness out. it was like a pink, nice smelling soup kitchen happened inside the car. They even accidently left a bottle of it under the drivers seat. spastics.
1 hour ago, joeyjoejoejuniorshabadoo said:
You literally just bought an R32 in the exact condition as the car the guy is making inquiries about
nah the new one is worse lol.
its pretty bad but saveable .
1 hour ago, Kinkstaah said:
Dumb question, is there any good BUDGET detailers? Somewhere where you can just go on a very low notice and get a reasonable to OK job of interior detailing because majorly CBF and car looks pretty shit 95% of the time anyway?
By "good enough" I mean good enough to think "oh yep, that's cleaner now" but with 0 desire to actually take a photo of it.
In springvale cnr of westall and osbourne i think? next to GT hyperauto
$15 for a hand car wash. not bad considering it takes em like an hour
I wonder what the IT section at Telstra is like....
Would it be filled with ex-public servants who just dont give a fark and do nothing all day.
Or would it be generally younger IT personnel who just dont give a fark and do nothing all day.
Or would it be a small team of extremely over-worked individuals that are constantly putting out fires and trying to resolve the countless issues that arise?
All of the above.
I took the 33 to a shopping centre carwash when i first got it.
dude used a pressure sprayer at close range to remove a birdshit and stripped a soccerball sized bit of paint off the bonnet
That just means you had shit paint doe
  • Like 1
S13 convertible in manual. i kinda like it because its stock? maybe thats what happens when all you see are S13 drift cops anymore
http://www.carsensor.net/usedcar/detail/CU5088407384/index.html?TRCD=200002
id love a stock s13 vert with the aero kit and R33 GTR wheels= porn
also, good mate of mine stacked his car last night, after a bucks party, into a house.
f**ked the house, nothing left of the car.
i really hope he just fell asleep at the wheel and wasnt being an idiot :(
the extent of the damage though, i doubt it.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
