30 minutes ago, Birds said:
12th November
Fitness Expo w/strongman
DECA
PIARC Sprint
Evil clashes
Yer i might go deca in the boat, not sure how i'd find my way through some of the cones with auto / won't be using the e-brake lol
Would any wastelanders be keen on sharing a room? I only masturbate furiously like 4 times
Edited by UNR33L
  • Like 1
I hated viet.
however I was working not being tourist, and representing a USA company so there was seem serious resentment among the staff.
Unfortunately looking like I'll be back there again a few times next year.
If i can make it to DECA ill share a room wit chou.
88e announcement is out. Hasnt stirred up much interest, but seems to be a decent result of conventional oil which is always nice, its not the focus of the project more so an incentive for buy-out. Give it another month and see what OPEC and oil price futures are doing...
52 minutes ago, emts said:
I hated viet.
It's pretty rife in their culture
Went to the war museum in Hanoi and latched onto the back of a school/military tour group; the guide was dressed in army garb talking about all the atrocities American soldiers committed whilst shedding tears...it was extremely biased and mentioned nothing of the treatment of American POWs, but as the only western looking person in the room I did a bit of a quiet segue into the next room.
Not a lot of interest on the whole market, wait 'til the US presidential election is done and dusted I think.
there is that.
What I loved was going into a shop and ask a price, they would give me a price in USD, explain not American from AU, and price would halve..then bargain down to a 1/3 of that price. not like AU was not involved in that war but all they think of is the americans!!
Talking to some locals apparently the vendors do sit around over a beer at night discussing who screwed over an american the most that day.
  • Like 1
I remember in Vietnam making friends with a bar owner from Denmark, end up chatting about motorcycles nek minit lets me ride his 'big bore' scooter 200cc I think (actually went pretty well compared to other scooters I've ridden) had a massive brake upgrade on it in my braking tests I ended up in a small bingle with another rider luckily didn't come off had the mrs on the back too no helmets doing stoppies and VERY drunk.
#yolo I guess
Leroy leme know soon brah
Edited by UNR33L
all the aussie airlines have.
that awkward moment when power goes out at home, so you decide youll work down the street with your laptop at the cafe, go to open your garage and forget it's powered roller door, and that your laptop is inside the car LOL
Someone needs to start a Facebook group for this frequently occurring phenomena
2 hours ago, Rekin said:
Lol at qantas outright banning the Samsung 7 on flights. I wonder what they do with the phone if you have one lol
Ffffffffffffffff what a time to be an iPhone user.
 Doesn't have a pull string to Disconnect the door from the chain so you can manually lift the door? Most do...
yea but car is parked right up against where the back door opens into, plus nfi where that key is to unlock it. exciting stuff.
just entered DECA considering it's cheap enough without needing cams/sau paying membership! I'll be slow af but should be good fun.
Edited by UNR33L
On 10/18/2016 at 10:58 AM, Birds said:
12th November
DECA
PIARC Sprint
Evil clashes
Are you starting to do circuit days?
Im looking to get back into motorsport
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
