25 minutes ago, blah_blah said:
Are you starting to do circuit days?
Im looking to get back into motorsport
I've done one, but that was enough to want to go again
  • Like 1
1 hour ago, UNR33L said:
yea but car is parked right up against where the back door opens into, plus nfi where that key is to unlock it. exciting stuff.
just entered DECA considering it's cheap enough without needing cams/sau paying membership! I'll be slow af but should be good fun.
I don't consider SAU and CAMS Memberships to be an expense, as having them both gets me a larger discount on my car insurance than if I didn't have them :P
  • Like 1
Makes sense for you, but for me not really - this will be first event in the car other than drags in 5 years and RACV insurance don't care about club for insuring it
I'm more into bike track days at the moment but figure I'll try something new, last car I did deca in was my white N/A 33 lol
Edited by UNR33L
With a car of your power, DECA is perfect to show it off. You staying? There's a single room left at our hotel if you're quick!
How much power does your car have leigh?
Yeah gotta sort out accommodation - which hotel you at? do I need to mention SAU??
ABOUT $3.50
It's all in the facebook event description. https://www.facebook.com/events/697794630372309/
There's a bit triathlon on in Shep that weekend, so lots of places are booked out. Go Go Go!
Oh lol, just looked it up... the Triathlon is on Sunday and starts early.
Sunday 13 November 2016
Transition Access (no bike check-in): 5:10am – 5:45am
Pre-race briefing: 5:50am at swim start
Start Time: 6:00am
I feel so sorry for those people staying at our motel :P
done - got the last room
do fire extinguishers have expiry dates / do DECA people care? also can it be mounted in the boot or have to be close to driver?
ok found this, I guess the boot technically counts as inside the vehicle right?
All vehicles must be equipped with a minimum 900gram fire extinguisher securely mounted inside the vehicle with a metal bracket. Extinguishers must comply with the Australian Standard – AS 1841 and not be more than five years old.
Edited by UNR33L
Close to driver - specifically - you need to be able to reach it from the driver's seat
Even though a fire at DECA is unlikely, so too is the usefulness of a fire extinguisher sitting in the boot
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
