^ whats wrong with it?
voted at council elections at 8am this morning. bloody only 3 people running. just get a committee to decide or f**king roll a dice or something. geez.
We had 20 running in Brunswick. Had to number them all too ugh
All a bunch of greenies full of hopes and dreams
lol, how to debate with a green:
"We need to battle climate change and put more money into environmental issues and open the doors for refugees"
"How you gonna pay for that?"
I never complain about eating Crab.
in fact I was planning on having some tonight.
and that was not a complaint about travel, more so about building house.
Swore no Motorsport till it done. I'm in town for deca, but only coming up to help run not enter.
that said once house done I have space for properly working on a car and can do it properly. and first time I will have all my cars in one spot for maybe 8 years!
has anyonehere built with carlisle homes? what are they like?
Im a domestic new home plumber, i do the work for 5 big name builders and then a lot of little ones,
Carlisle aren't one of them,
I haven't heard much bad about them, but i haven't heard anyone raving about them
Boutique are doing extremely well these days.
My old man is building some units in highett with leneeva homes
Carlisles structural guarantee is 10yrs
Metricon is 25
Burbank is 30
And henleys is 50!!
Metricon is 25
Burbank is 30
And henleys is 50!!
That was the most long winded way if saying "no" I have ever seen
  • Like 1
Metricon is 25
Burbank is 30
And henleys is 50!!
i was froffin the carlisle designs, dennis family homes was the gayest shit ever, its like hamish was an interior designer/builder and designed that shit, will look up burbank and henleys
  • Like 1
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
