There's no shortage of second & third tier lenders that will fall over themselves to give people loans at excruciatingly high rates...
Remember Bankruptcy does not mean you can't borrow money, just that you can't be a director and a few other things...
Credit defaults are for the lender to be able to make an informed decision, they don't mean no one will lend to you if you have solid justification
10 hours ago, emts said:
I'm just trying to work out how they get offered 400Kish on low income with a bankrupcy
thought loans were getting harder not easier.
Spose it depends if was a Part 9 or Part 10 insolvency or full bankruptancy
In any case it should stay on the credit history and just mean muchharder to get a loan and should get higher interest rates
Hamish a question since you work at the bank
Do Banks offer mortgage brokers and public the same interest rate?
The commission that mortgage brokers get is that seperate or built into a higher interest rate offered to a mortgage broker from the bank
We offer the exact same products via both channels - some brokers may try to lead clients towards the more expensive product that gives them a better commission however this is actually not allowed as brokers are required to be at arms length from product selection.
The commission is paid by the bank and not the client nor the loan
They will all flag that the client would be considered higher risk and all appear on credit files.
A part IX and X really mean the same thing, the main difference is the expense in applying for the X due to the CPA requirement.
What are the chances that of the two ssds in the laptop, the one I put in the dock first was never used as the other one never reached capacity? Unlikely I'd imagine, but I only tried one of the 2 last night.. I'll try the second one tonight but I'm not expecting anything different..
You are totally the Greg of computers
  • Like 1
Intradastng
That clears it up.
Just thought it was weird when i tried applying for a home loan my broker couldnt match my interest rate with the big fours when i went direct. Maybe just a crap broker.
And shares
computers/shares
computershare
thats jus a lil stock market humour
  • Like 1
It's got 2 x 128gb ssds and the 1TB sata ..just plugged the second ssd into the dock, it came up as E drive straight away but then followed by a 'disk needs to be formatted' message..
Opened disk management and it's showing more info than with the other one... Can anything be recovered from it?
Ummmmmm, the two 128GB SSD's weren't set up as a RAID 0 array were they?
If so, you won't be able to access the data on either of them without them both being plugged in and having a Raid controller that knows what to do with them
  • Like 1
If it has two and they were in raid0, you won't be getting anything off of them without having the same chipset to plug them into. (Basically not going to happen)
raid1 is a better setup to be running if you have the choice, but you only get the space of one drive and you can recover from a dead drive or a dead computer as both drives contain all the same data without requiring the chipset that put it on there to read it.
I disagree with manufacturers selling products with raid0 setups, that shouldn't be an option for most people as they don't understand the risks and drawbacks involved in doing it, just put the one bigger Pci-e ssd in it, it's easily faster than two sata ones anyway.
  • Like 1
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
