There's no shortage of second & third tier lenders that will fall over themselves to give people loans at excruciatingly high rates...
Remember Bankruptcy does not mean you can't borrow money, just that you can't be a director and a few other things...
Credit defaults are for the lender to be able to make an informed decision, they don't mean no one will lend to you if you have solid justification
10 hours ago, emts said:
I'm just trying to work out how they get offered 400Kish on low income with a bankrupcy
thought loans were getting harder not easier.
Spose it depends if was a Part 9 or Part 10 insolvency or full bankruptancy
In any case it should stay on the credit history and just mean muchharder to get a loan and should get higher interest rates
Hamish a question since you work at the bank
Do Banks offer mortgage brokers and public the same interest rate?
The commission that mortgage brokers get is that seperate or built into a higher interest rate offered to a mortgage broker from the bank
We offer the exact same products via both channels - some brokers may try to lead clients towards the more expensive product that gives them a better commission however this is actually not allowed as brokers are required to be at arms length from product selection.
The commission is paid by the bank and not the client nor the loan
They will all flag that the client would be considered higher risk and all appear on credit files.
A part IX and X really mean the same thing, the main difference is the expense in applying for the X due to the CPA requirement.
What are the chances that of the two ssds in the laptop, the one I put in the dock first was never used as the other one never reached capacity? Unlikely I'd imagine, but I only tried one of the 2 last night.. I'll try the second one tonight but I'm not expecting anything different..
You are totally the Greg of computers
  • Like 1
Intradastng
That clears it up.
Just thought it was weird when i tried applying for a home loan my broker couldnt match my interest rate with the big fours when i went direct. Maybe just a crap broker.
And shares
computers/shares
computershare
thats jus a lil stock market humour
  • Like 1
It's got 2 x 128gb ssds and the 1TB sata ..just plugged the second ssd into the dock, it came up as E drive straight away but then followed by a 'disk needs to be formatted' message..
Opened disk management and it's showing more info than with the other one... Can anything be recovered from it?
Ummmmmm, the two 128GB SSD's weren't set up as a RAID 0 array were they?
If so, you won't be able to access the data on either of them without them both being plugged in and having a Raid controller that knows what to do with them
  • Like 1
If it has two and they were in raid0, you won't be getting anything off of them without having the same chipset to plug them into. (Basically not going to happen)
raid1 is a better setup to be running if you have the choice, but you only get the space of one drive and you can recover from a dead drive or a dead computer as both drives contain all the same data without requiring the chipset that put it on there to read it.
I disagree with manufacturers selling products with raid0 setups, that shouldn't be an option for most people as they don't understand the risks and drawbacks involved in doing it, just put the one bigger Pci-e ssd in it, it's easily faster than two sata ones anyway.
  • Like 1
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
    • To re-cap, I bought: https://www.alibaba.com/product-detail/Lsailt-8G-Infiniti-Q50-Q60-2014_1601171829627.html?spm=a2756.trade-list-buyer.0.0.2cd476e9FTIlKE As you can see, if I bought 20 it was $653, but I bought 1 so it was $1,170. I was very tempted to buy 2 and resell 1 at 25% cheaper. @MBS206, I am not sure if they do a Kluger one, here is their list but it might be there under a global model name: http://www.lsailt.com/product/android-interface?page=1 Keep in mind these full android replacements have basically all the bits a phone does (cpu, ram, storage, wifi, bluetooth, usb interfaces) other than a screen (it uses a host), thus the $800+ cost. Android Auto screen mirroring is MUCH cheaper as it's just a cut down shell, input mirroring and output mirroring BTW I also need that "screen off" feature, it is much harder to see wildlife even if a dash is reasonably dark. Both the Fuga and V37 have display off buttons for night use, they just come back on for a second or 3 if you interact with it, eg skip a song.
