There's no shortage of second & third tier lenders that will fall over themselves to give people loans at excruciatingly high rates...
Remember Bankruptcy does not mean you can't borrow money, just that you can't be a director and a few other things...
Credit defaults are for the lender to be able to make an informed decision, they don't mean no one will lend to you if you have solid justification
10 hours ago, emts said:
I'm just trying to work out how they get offered 400Kish on low income with a bankrupcy
thought loans were getting harder not easier.
Spose it depends if was a Part 9 or Part 10 insolvency or full bankruptancy
In any case it should stay on the credit history and just mean muchharder to get a loan and should get higher interest rates
Hamish a question since you work at the bank
Do Banks offer mortgage brokers and public the same interest rate?
The commission that mortgage brokers get is that seperate or built into a higher interest rate offered to a mortgage broker from the bank
We offer the exact same products via both channels - some brokers may try to lead clients towards the more expensive product that gives them a better commission however this is actually not allowed as brokers are required to be at arms length from product selection.
The commission is paid by the bank and not the client nor the loan
They will all flag that the client would be considered higher risk and all appear on credit files.
A part IX and X really mean the same thing, the main difference is the expense in applying for the X due to the CPA requirement.
What are the chances that of the two ssds in the laptop, the one I put in the dock first was never used as the other one never reached capacity? Unlikely I'd imagine, but I only tried one of the 2 last night.. I'll try the second one tonight but I'm not expecting anything different..
You are totally the Greg of computers
  • Like 1
Intradastng
That clears it up.
Just thought it was weird when i tried applying for a home loan my broker couldnt match my interest rate with the big fours when i went direct. Maybe just a crap broker.
And shares
computers/shares
computershare
thats jus a lil stock market humour
  • Like 1
It's got 2 x 128gb ssds and the 1TB sata ..just plugged the second ssd into the dock, it came up as E drive straight away but then followed by a 'disk needs to be formatted' message..
Opened disk management and it's showing more info than with the other one... Can anything be recovered from it?
Ummmmmm, the two 128GB SSD's weren't set up as a RAID 0 array were they?
If so, you won't be able to access the data on either of them without them both being plugged in and having a Raid controller that knows what to do with them
  • Like 1
If it has two and they were in raid0, you won't be getting anything off of them without having the same chipset to plug them into. (Basically not going to happen)
raid1 is a better setup to be running if you have the choice, but you only get the space of one drive and you can recover from a dead drive or a dead computer as both drives contain all the same data without requiring the chipset that put it on there to read it.
I disagree with manufacturers selling products with raid0 setups, that shouldn't be an option for most people as they don't understand the risks and drawbacks involved in doing it, just put the one bigger Pci-e ssd in it, it's easily faster than two sata ones anyway.
  • Like 1
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
