Lol so my daughter decided to wash my iPhone... Literally wash under the bathroom tap....
So I pulled out my galaxy 5 and went to use that... Performance was shocking.... Upon investigation noticed there was 4.5gb of complete bullshit loaded into the misc files section...
I'll give you one guess as to what app it was
Pornhub have an app?
  • Like 1
I imagine some sort of app where you enter the meal that you would like to make, it "deconstructs" it and automatically lays out the ingredients in an aesthetically pleasing way on a fence pailing so you can serve it to bearded hipsters.
I can't believe that would be 4.5gb of space though, was it two drives in Raid 0? If so, you're stuffed.
  • Like 1
1 minute ago, Birds said:
I choose humour over sensible truth everytime, hence my answers
ah but you see the porn sites are some of the smartest about security of all internet companies..
no-way they would be silly enough to cache stuff on your phone for you to get in trouble with your work.
If you ever want to see a correct way to manage security/users check out something like Adultshop/sexyland/any porn site.
nengun gets hacked no big deal..esp if you have different passwords for each site (which we all have right...)
but XXX site gets hacks and it's much worse PR and most likely out of business.
not so much ashley madisen however
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
