Don't forget about the bet he had with Barry about having it finished by Christmas time last year or lunch is on them.
did they buy subway? I'm guessing subway.
Pats car isn't too far from being on the road, and that build got a lot bigger than originally planned...
  • Like 1
Admittedly going against my own advice with that setup, as I don't know of anyone who's shot for response / disregarded power on a stroked GTR at the risk of choking their turbos etc. But GTR people are funny and in a lot of ways retarded - to many of them, responsive means boost by 4500rpm hence the catch cry "put -10s or huge single on it bro" (aka "what's a gearbox / traction?") etc. Your redline might be 8000rpm but you don't have to use it.
Responsive to me is /full/ boost by 3000-3500 and not needing the top 2000rpm because you can pull hard in any gear. The cars are quick in their own right from factory and hardly laggy. Increase in displacement with a proportionate increase in turbo size should produce a much faster version of the factory vehicle without sacrificing drivability or breaking parts. 4th gear roll ons from 80 and such...
The -9s came with the car, so am happy to buy something bigger down the track if the experiment fails.
  • Like 1
1 hour ago, TiTAN said:
Being one of the early 3l crowd. It seemed far easier and cheaper than it actually turned out to be.
Doing it again would keep the 25 and go a 3071 or 3076. Job done, solidly fast car, not a lot of $$.
Be worth it in a drag setup or something with great traction, but considering what the cars can do just fine with 2.5 litres and those turbos...
When I was deciding on turbo for GTS-T I spoke to people who formerly had high flows and then upgraded to 3076 or GT35 etc. Each one said if they had their time again they'd just have stuck it out with the high flow...keeping this in mind has helped me avoid chasing any more power in it.
lol, so does everyone else who has a car that sits out of the front of Edge.
got curious about supra prices. lol.
https://www.carsales.com.au/private/details/Toyota-Supra-1996/SSE-AD-3503755/?Cr=3
" The interior and exterior is in perfect original condition. Unmarked. " every drive is always excitement in a super car " Body modification kit and additional three coats of optic silver paint by pro body shop." I am the second driver and owner of the car, bought from a Japanese business friend " Body kit: Calsonic USA (exclusive one off ): " 275 X18 "inch rear..Max..super grip. "
Mine is an inside resident
And likely safer there than at my new address
Reminds me, I need to increase my agreed value
Also Supras have gone the way of GTRs. RX7s too. Would invest years ago.
I kinda did this. When I first got my car it took a while to climb up on boost.
One of my requests with it being retuned was to make more torque at lower RPM. We (Racepace) basically moved the power band down approx 1000 rpm.
The car is much nicer to drive on the road even if it is 100kW down at the tires. It's a good middle ground for drivability.
How was this achieved? Through tune alone or camshafts / gears?
When I had my GTS-T tuned by Chris I told him I wanted midrange, didn't care about top end. Torque wins drag races, afterall lol
all i wanted was a rb20 refresh and now we are here...although the gtx3071 is tucked below, a large manifold spacer was used which i fear will cause the dump to clash with the aircon lines...thats Havoc's problem when he will be fabricating custom intercooler piping, airbox intake pipe & dump pipe...
  • Like 1
10 hours ago, Kinkstaah said:
I have been a few times, I did 11.9 on my old setup with AD08R's and an intercooler pipe blowing off half track because of course something like that would happen to me.
So it was a nice weird time of a 11.9 at 116mph with a 2.2s 60ft.
I went weekend before last to test and tune with the BW EFR and MT drag radials and went slower because I had even less grip cause it turns out the tyres I bought are 10 years old because of course they are  and my 60ft was 2.6.
My car only makes 320kw atm :P
If I was Toby, for simplicity's sake I would put the GTX3071 on. Simply because it bolts on. Saves time, saves money, will work 95% as well in all the scenarios that exist. The EFR can be "made" to fit, but who is making it fit? The one thing I learned fitting it is that it is NOT bolt on, even though everything "should be" things don't always line up, you have to move this, fabricate that, take 6 hours thinking "Where am I gonna run this line..." or "I dont like how this fits..." or "This is gonna get hot..."
Enjoy car. Do skidz. Do track events. Don't overcomplicate things. Don't chase other's results. Someone just made 413 KW On a 7163 (!!!) on a Golf R, which will make everyone sad at the traffic light grand prix. Someone out there will buy a new Huracan. Aim for fun, and what you want first then think of the simplest way to get there.
So hurr durr why didnt I just do that? Cause I had planned on changing the setup anyway, I wanted a much larger rear housing and a more flowy manifold which ruled out leaving things where they were. I had a GTX3076R on my car int he past, and it dropped/choked 150RWKW after 6k from peak power, so as I wanted less power, I needed to open up the rear end MASSIVELY and that's why I have the setup I have now.
2.8 and a flowed head is amazing for flow but it has to flow somewhere. Swapping to a GTX3076R was the same cost for me as going BW. I initially wanted to just go back to a GTX3076R with a larger rear housing, but doing it "properly" resulted in the BW being the same price once the GTX3582 was sold. Also someone please buy my GTX3582.
TLDR: Do as I say, not as I did, never ever do what Greg did.
Long essay lol
Still leaning down the BW path but will see. $2.5k for a GTX turbo or $3k for a BW EFR plus paying for fabrication to make it fit is all the same same to me. Headaches wont be a problem as id be just paying someone else to take on the problem :30_no_mouth:
Will wait and see how Pats Gen2 GTX drives, but if im gonna spend $$ on changing turbo setups i may as well go EFR. (Hey greg if you want to sell your setup..lol)
28 minutes ago, Kinkstaah said:
Hey man if you want you can have my entire car and/or everything in the engine bay. You know how much it costs as you know the guy who built it :P
What's the retail of an auto R34 sedan these days? How about $5k? :30_no_mouth:
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1680, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
