18 minutes ago, Leroy Peterson said:
What sort of issues do people have if plugs too cold? If I run 8's on the street... Would I be better off saving 8's for track days only?
Fouling and yes. BTW, please pay $400 to photobucket so they can show your images.
My plugs were just fouly (which is odd because we had them cleaned when my turbo went on.. maybe a month/1500kms ago), and previously were never that state. My specific plugs looked like this:
So there wasn't a great deal of room for anything when carbon gets involved. But yeah, they were a bit "Carbony" which is odd because E85 generates less carbon and 'fouling'.
But yeah, misfires at idle/very low load and misfires at 20psi, Carboning up, looking rather "tan" or a darker tan than mentioned made me think they were no longer the best option.
All hail BCPR7ES (I bought 18) :P
Crisitunity
There is a Melbourne 88E shareholder meet up tonight, you should go meet some of your new pals.
I picked up 80,000 shares this morning for cheap, so that's paid for by approx tax return.
Feeling even better about my 6.4c sell a few weeks ago now
Yeah good move.
See if it hits a new low tomorrow from pommy influence, but I'm just gonna wait it out. They still haven't used artificial lift yet... 11,000 ft is a long way.
Details? I did not know about it
Another 30,000 for me
https://hotcopper.com.au/threads/melbourne-88ers.3535713/#post-25763781
I picture it in my head a scene similar to ^ that, but I know it would be the complete opposite.
Traralgon Toyota don't carry stock for 2006-2011 Hilux front rotors. And takes them over a week to get stock from Melbourne.
It's probably the most common hilux model in gippsland and a consumable part. They stock the brake pads but "we don't replace brake pads unless the rotors are done at the same time". So why would you stock one and not the other??
I've been to obscure car club meets, motorcycle club meets, LANs with people only known through internet, and the Melbourne screening of The Red Pill...I've learned to expect absolutely anything and the term "all shapes and sizes".
When work throw out over 2 grand worth of old equipment doing a cleanup, I'll take that.. already sold it too, self bonus.
Also had what looked to be Joffa look at my car on Sunday to possibly buy :D
Edited by UNR33L
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
