18 minutes ago, Leroy Peterson said:
What sort of issues do people have if plugs too cold? If I run 8's on the street... Would I be better off saving 8's for track days only?
Fouling and yes. BTW, please pay $400 to photobucket so they can show your images.
My plugs were just fouly (which is odd because we had them cleaned when my turbo went on.. maybe a month/1500kms ago), and previously were never that state. My specific plugs looked like this:
So there wasn't a great deal of room for anything when carbon gets involved. But yeah, they were a bit "Carbony" which is odd because E85 generates less carbon and 'fouling'.
But yeah, misfires at idle/very low load and misfires at 20psi, Carboning up, looking rather "tan" or a darker tan than mentioned made me think they were no longer the best option.
All hail BCPR7ES (I bought 18) :P
Crisitunity
There is a Melbourne 88E shareholder meet up tonight, you should go meet some of your new pals.
I picked up 80,000 shares this morning for cheap, so that's paid for by approx tax return.
Feeling even better about my 6.4c sell a few weeks ago now
Yeah good move.
See if it hits a new low tomorrow from pommy influence, but I'm just gonna wait it out. They still haven't used artificial lift yet... 11,000 ft is a long way.
Details? I did not know about it
Another 30,000 for me
https://hotcopper.com.au/threads/melbourne-88ers.3535713/#post-25763781
I picture it in my head a scene similar to ^ that, but I know it would be the complete opposite.
Traralgon Toyota don't carry stock for 2006-2011 Hilux front rotors. And takes them over a week to get stock from Melbourne.
It's probably the most common hilux model in gippsland and a consumable part. They stock the brake pads but "we don't replace brake pads unless the rotors are done at the same time". So why would you stock one and not the other??
I've been to obscure car club meets, motorcycle club meets, LANs with people only known through internet, and the Melbourne screening of The Red Pill...I've learned to expect absolutely anything and the term "all shapes and sizes".
When work throw out over 2 grand worth of old equipment doing a cleanup, I'll take that.. already sold it too, self bonus.
Also had what looked to be Joffa look at my car on Sunday to possibly buy :D
Edited by UNR33L
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
