47 minutes ago, joeyjoejoejuniorshabadoo said:
Been driving to the new.job for a few months now. Gotta admit it would be f**king hard to go back to the filthy train
Ignorance is bliss
I'm still on the free early morning train..... train
  • Like 1
6 hours ago, UNR33L said:
Arguments on both sides, some would say no point having a cheap daily if that's what you spend most time in, obviously if you could have a baller daily and baller weekender that's different, I'm going down that path with motorbikes though, track bike and road bike, at least they're cheaper $.
I thought 9.5? Check out some of the Vertini, HRE, Niche etc , thewheeldeal website has some good options, I think eastcoast tyres also recently opened a shop in Bayswater (they are big in sydney for holden and ford ranger boys)
Nah...cheap daily pros:
- Appreciate nice weekender more
- Less f**ks given if it's stolen or smashed
- Less depreciation from high mileage
- Generally better fuel economy
- No compromise made on the weekender which can have two doors and no tow bar
- Auto daily, manual weekender
All rounders compromise somewhere...in comfort or fun factor
All in one. Daily and track hack. No f**ks given for fuel economy or if it gets smashed or stolen. Comfortable enough as long as there's no speed humps and fast enough at the track to leave some dedicated track cars with a wtf look. If I needed to, I'd consider a tow bar. R33 GTST, perfect weapon for that type of thing. Definitely a compromise but still works damn good.
This is what I'm doing now and it is one of the better cars to pick as an all rounder, but if I had the space I'd have an econobox auto daily for sure. Probably a Hyundai as their recent models are damn good value for money.
When I had a 34 GT-T auto with stock suspension, it made me appreciate the 33 manual more on weekends and vice versa.
The 33 won't work for everyone but in my current circumstance, it's perfect. I have an m35 stagea which is as comfy as driving a sofa as a back up car/workhorse but would rather daily the 33. Why have a fast car and drive a slow car everyday. It's just not something I can do. I've never driven anything slower than a 14 sec car and I'm not about to start now. Yes, there are newer tech cars out there that can do the job but then you've got to factor in depreciation, costs to make them faster and most of them don't make you feel like your really driving.
If I was you birds, I'd keep dailying the GTST and track it if you feel the need and have gtr as weekend duties mobile.
What happened to F-Zero winning rims Billiam?
I barely drive on the weekends as it is, and if I do it's to the track anyway(towbar) or to coles, fuel economy negated by having to pay rego, insurance, maintenance on a 2nd car.
I wouldn't want to spend 6-10 hours during the week driving a shittier daily to only have much less time in a nice weekender.
Auto daily and manual weekender would be nice though.
Edited by UNR33L
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
