What was he driving?
I'm assuming you've got no idea who it is
Didn't see.. Wife just told me it was green P's
Wouldn't have a clue... Been told who it was but don't remember/care. I do remember he plays for St Kilda though
Took the STI for a roasting down Dandenong tourist road, thing feels like a gokart!
Once I hit the bottom brakes doing some nice squeaking, bedded dem babies in nicely. Stopped after a while which was good :)
Ordered a tow bar the other night so I can be a cool cat and tow a jet ski, this counts as first mod right?
I'm familiar with the relative size of modern jet skis
They are boats compared to their 90s counterparts, which you used to get thrown off so much more easily at lower speeds
Stability and top speed have come a long way
considering the amount of contact they have it makes complete sense. Unlike a car with 4 small rubber patches they have an entire hull available to them.
but that friction does impact them in straight lines, (thus why they like to get bow out of water)
used to watch the offshore power boat racing, the cornering some of them did were unbelievable, but my god the costs involved..
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
