On 15/01/2018 at 3:15 PM, UNR33L said:
Also fun fact, the colour she chose was called "Tangerine Scream" (It's yellow)
Because the only way you think it looks good is if someone squeezes citrus into your eyes?
Frankly, I'm astounded that securities inflated by a rampant media frenzy and subsequent societal trend of less-than-astute first time / me too investors might one day burst like a bubble
Or that cryptocurrency should function just like any other technology...
FWD performance makes sense upto a certain power level I guess, I mean if you are just using on the street its fine I guess too, unless you're Birds and feel the need to race every set of lights :P
Basically looks like what Simon posted except with the better looking rims that we get in Aus and no weird pin stripe.
The yellow / blue / red all come with accents inside on the Recaros so kind of make them the "go to" colours, if you go white silver etc. you just get fairly boring grey interior.
Edited by UNR33L
Things are sinking today, but Neo is behaving strong. Made 0.03BTC on 3 neo trades of 10 Neo in the last 24hrs,and I don't even day trade. Will hold. So far it's just undoing what was ramping in December. Still more valuable than what it was 2-3 months ago.
Hard to ignore that the total crypto value of under $16 billionUSD in January 2017 to $800billionUSD at start of Jan 2018.
30 minutes ago, UNR33L said:
The yellow / blue / red all come with accents inside on the Recaros so kind of make them the "go to" childrens/boyracer colours, if you go white silver etc. you just get an fairly boring adult grey interior.
FYP
Yeah you are right, that doesn't sound like a bubble at all...
On 1/16/2018 at 5:30 PM, joeyjoejoejuniorshabadoo said:
I don't understand the point of FWD "performance" cars
Drive one. Magical diff, pft I said.
Then I drove it and I was like oh. Renault newish stuff is criminally underpriced and is as reliable as any other hot hatch. Drove it for 2 weeks, no regrets. Down to 12k but would gladly take one for a drive over an Evo X.
  • Like 1
I'd rather own part of a company than part of a USB stick
Got some railroad bonds for you krypto kids if you're interested
I'd probably rather own whichever was worth more.
Or whichever recovered the next day rather than over the course of 2 years.
  • Like 1
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
