On 15/01/2018 at 3:15 PM, UNR33L said:
Also fun fact, the colour she chose was called "Tangerine Scream" (It's yellow)
Because the only way you think it looks good is if someone squeezes citrus into your eyes?
Frankly, I'm astounded that securities inflated by a rampant media frenzy and subsequent societal trend of less-than-astute first time / me too investors might one day burst like a bubble
Or that cryptocurrency should function just like any other technology...
FWD performance makes sense upto a certain power level I guess, I mean if you are just using on the street its fine I guess too, unless you're Birds and feel the need to race every set of lights :P
Basically looks like what Simon posted except with the better looking rims that we get in Aus and no weird pin stripe.
The yellow / blue / red all come with accents inside on the Recaros so kind of make them the "go to" colours, if you go white silver etc. you just get fairly boring grey interior.
Edited by UNR33L
Things are sinking today, but Neo is behaving strong. Made 0.03BTC on 3 neo trades of 10 Neo in the last 24hrs,and I don't even day trade. Will hold. So far it's just undoing what was ramping in December. Still more valuable than what it was 2-3 months ago.
Hard to ignore that the total crypto value of under $16 billionUSD in January 2017 to $800billionUSD at start of Jan 2018.
30 minutes ago, UNR33L said:
The yellow / blue / red all come with accents inside on the Recaros so kind of make them the "go to" childrens/boyracer colours, if you go white silver etc. you just get an fairly boring adult grey interior.
FYP
Yeah you are right, that doesn't sound like a bubble at all...
On 1/16/2018 at 5:30 PM, joeyjoejoejuniorshabadoo said:
I don't understand the point of FWD "performance" cars
Drive one. Magical diff, pft I said.
Then I drove it and I was like oh. Renault newish stuff is criminally underpriced and is as reliable as any other hot hatch. Drove it for 2 weeks, no regrets. Down to 12k but would gladly take one for a drive over an Evo X.
  • Like 1
I'd rather own part of a company than part of a USB stick
Got some railroad bonds for you krypto kids if you're interested
I'd probably rather own whichever was worth more.
Or whichever recovered the next day rather than over the course of 2 years.
  • Like 1
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
