On 11/16/2022 at 1:44 AM, Mohsen said:
Not much, my beard finally connects.
fuaaaaaarkk get out kent! my boi's all growd up!
does this mean you now instantly get profiled as a suspect?
  • 3 weeks later...
On 5/13/2021 at 4:21 PM, Leroy Peterson said:
it fluctuates, but my 1080 & i7 8400 are churning out ~$100aud/month if left on 24hrs. That's with BTC price hovering like it has for the past 13 weeks. But since a recent update, seen a 20-55% increase in payout.
I think its important to come up with a gameplan for each cycle. I've learned a lot in the last 6+ months so hopefully can apply that next time and during the bear market.
Planning on buying a house later this year... so sadly will have to liquidate a lot. Using crypto as collateral for loans or mortgages is even closer than people think... I'm annoyed no one will accept anything other than house equity as collateral. That shit is sooo 1980's.
How's the bear market working out? Did you cash out in time or in for the long haul?
I pulled some out on the way down. Planned to keep most for the long haul but I was stupid and deposited a lot into platform(s) that went under. I knew the risk but I had no idea how f**king stupid some of these companies/platforms actually were.
In terms of mining, it was kinda profitable but chump change really in the scheme of things. Basically covered transaction fees.
NiceHash mining is dead now due to ethereum halting mined blocks.
2022 really showed how f**ked the the industry is. Much more than I thought. I'm proper bearish in 2023 and will sit on the sidelines until some quality people/businesses start to run things or set an example. The damage could be done though, banks won't touch any crypto firm now. Some did pre-2022. There was so much money sloshing around that the big crypto firms were buying tiny banks in jurisdictions just to be able to try and withdraw currency.
yeah man got a pat down from a cute jap chick at the airport lol.
  • 1 year later...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
