I saw that engine come up while mine was currently being finally built correctly it would appear.
Did think "yeah if that was a fair amount lower I'd maybe be interested maybe"
If a perfectly good neo is for sale 6 months then man people are clearly getting them elsewhere :P
11 minutes ago, joeyjoejoejuniorshabadoo said:
I must know what these chemicals are....
for... err... research
yes, that'll do
This, or similar... I've used it in the past to make some floatation cells for my boat, stuff is noxious as fk and cleanup is impossibro!
https://www.amazon.com/Liquid-Urethane-Foam-Density-Quart/dp/B007V231P6
yes, that'll do
annoying way to reference it, but think it was this one, Lots of O2 released so flames are easy.
that stuff is non flammable (well meant to be, plus the liquid color is wrong, they are pouring in a perfectly clear liquid.
5 minutes ago, Leroy Peterson said:
its called the elephant toothpaste experiment.
but that way it sounds boring...experiment!!!
https://en.wikipedia.org/wiki/Elephant_toothpaste
so the chemicals as per above.
oh crap found the original with subtitles...
they added petrol to the mix to give added flammability!
19 minutes ago, Rekin said:
Wrecker quoted me $3300 including gearbox, loom & ecu.
It won't move until it's $1800~
You don't need a 25 gearbox if you're not going past 250ish
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
