On 5/31/2017 at 9:33 PM, dezz said:
Who was it that posted that consumer law stuff about warranty not mattering, product working for a reasonable period of time etc...
What would be a reasonable period of time on an oven (residential)
I actually tried finding this earlier today while doing some consumer readings with no success.
According to one of my ex work team member, she got her Samsung replaced from the manufacturer despite it being out of warranty as there's a standard expectation of white goods in it's life expectancies.
Warranties are separate from your automatic consumer guarantees.  The consumer guarantees which apply regardless of any warranties suppliers sell or give to you, apply for a reasonable time depending on the nature of the goods or services. This means consumer guarantees may continue to apply after the time period for the warranty has expired.
https://www.accc.gov.au/consumers/consumer-rights-guarantees/warranties
Hence it pretty much comes down to what the VCAT mediator thinks is reasonable
In this day and age brands are more likely to fix the issue and bill you lowly or not at all because not worth the negative word of mouth and social media etc.
This... I made dishlex replace my out of warranty dishwasher and give me a free 5 year extended warranty on the replacement.
Just posted a shitty review online and they "came to the rescue"
(on a site I knoew they monitor and always reply)
1 hour ago, dezz said:
Hypothetically, can one claim things like exhaust, tune, supercharger kit etc as maintenance when doing their car expenses for tax purposes?
Toby?
You can claim anything you want
Whether it red flags an audit or not is another thing
Tax is surprisingly subjective - if you can reasonably justify its use then it counts. Can't see a situation that would require those things but maybe the workshop can draw you up an invoice for repair labour without itemising those specific things...
Vehicle has to be used to conduct work though, not just driving to and from work.
I know an old boss used to do a lot of "preventative maintenance" to his Ute, and it always ended up making more power or being less sensible in some way afterwards.
As far as I am aware it was all/partially claimed back in tax, how legit that is I have no idea though.
Yeah well, legit just comes down to justification. The more you claim or the more crazy stuff you claim, the more likely you will be flagged in the system for review / audit (though some audits just happen at random as far as I know). Despite audit being a huge pain in the ass for someone, as long as you can justify with records/proof of your claims then you will be okay / they will only ever knock you back for it if they deem the item unreasonable to claim. If they see that you've made an honest mistake and you don't have a history of bad tax returns they won't penalise you for it.
A tax return is simply saying "I shouldn't have paid tax on this item because x reason". The system sucks, but if you're not exploiting loopholes and all that jazz then you're one of the suckers paying more while those who know the system pay less.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
