Hi guys, I'm new to SAU-read a lot of your posts though & very helpful. I'm currently waiting to import Black R34 gtt in Auto(yes I can drive manual though prefer Auto slightly more) & I'm wondering if you guys know the maximum potential of an auto r34? Planning on modding it with all usual suspects eg 3" cat, intercooler, new ecu + e85 & upgrade transmission etc. what could I expect -max hp wise??? Thanks in advance
https://www.sau.com.au/forums/topic/458916-max-hprwks-for-r34-gtt-auto-manual/
The potential of a stock box? Not much more than stock power (with a tune)
Potential of a box with $3,000 spent on it? A lot more than stock power.
Don't chase 300rwkw+ with a factory auto, you're gonna have a VERY bad time,
Thanks guys. I sold my N/A r34 because I'm now ready to chase high HP. I have a performance guy/garage that I'm close with in Northern Melbourne & yes I will be going bigger turbo, maybe Garret. Just need to decide on tuner. Just need to confirm R31Nioid, if I upgrade "slush box" (auto haha) then I can chase 600-700 hp at flywheel? Thanks guys
Yes
Greg managed 400kw from his 34, but it is a built 2.8 with a built auto.
I would be looking to keep it around 300kw, for auto longevity, but it will need a valve body upgrade and large trans cooler at a minimum.
I have few grand to star Gtstboy but doing tax soon & expecting descent return as industry I'm in (not porn industry but am considering it) ha. Also Scotty- is Gregg's an rb26 stroked to 2.8? And sorry(I'm no expert) but what is a valve body upgrade?
I don't think there much money in the porn industry for a male , unless your planning on man on man..
cheers
darren
  • Like 3
It wil be fine..its a R34 auto...even if it makes 400rwkw, half the pulls it will only show 300ish..lol, then 250, then 350, then whatever the f**k it wants..lol
cheers
darren
Edited by jet_r31
  • Like 1
Nahhh Darren, no man on man here mate!!! Sorry to disappoint haha. Anyways, so Darren do autos pull all over the shop in kws? Ps. I will have more than 2 grand for modding, just over a few months or so. I really don't want to go manual-but if huge difference in kW capabilities then maybe think about it. Or try rb25/30 on auto with built box
