On 18/12/2022 at 8:37 PM, Kinkstaah said:
Drove through a booze bus today, Cop was all "Does that have a 25 Neo in it?" Said "Oh no, it has a LS" and opened the door and pointed to Engineering plate and told him it was all above board officer.
I got a solid thumbs up.
no RB can have that peace of mind! 😛
I suppose when you've been Gregging it so hard for so long you learn how to do things properly. That would've been satisfying showing the cop the engineering plate 👍
I just have a garage full of stock parts to put back on if I ever get reemed hard by highway patrol.  Varex is handy in not drawing attention and I've gone through a couple of booze buses without issue to date🤞
  • Like 1
On 18/12/2022 at 12:22 PM, admS15 said:
...Temp is a rock solid 88° now as indicated by the Android gauges....
Hey man, does the temp go up if in stand still traffic? Mine also usually floats around 87-88c but gets up to 90-91c if in traffic, and I have been told that those numbers are too high.
Not too sure if I should be getting worried or not, thanks.
Not sure, I don't encounter traffic but I don't think so. It wouldn't really worry me getting to 90-91. If it got to 95+ I'd be getting concerned.
On 19/12/2022 at 8:03 AM, Dose Pipe Sutututu said:
Probably drop an oil pump on the way out lol
Shh🤪
  • Thanks 1
  • 3 weeks later...
Took this out for a spin to the Dandenong mountains, was a crappy day for it, pretty wet but the Mrs had her sister over today and I couldn't think of a better way to get out of the house.
The main road up the mountain is in such poor condition and the tein coils were not very happy, neither was I tbh.  Was genuinely scared, the teins are woeful on any sort of bumpy surface. I got stuck behind a VW combi at one point and was actually quite happy to just sit behind.
Anyways, finished my time up there with a couple of runs up and down Forrest Rd which is a nice bit of rd, probably around 7km worth. Wasn't much traction as it was wettish but I kept at it to get an understanding of the safe wet limits of my car. I left the Dandy's satisfied.
Had an uneventful drive back home and then decided it was the perfect time to do a hot comp test. Results where a little better than the cold test a few weeks ago, mainly more consistent. Readings where between 151 to 162psi. Pics below from 1 to 6 for my records.
#1 160 psi
#2 160 psi
#3 160 psi
#4 152 psi
#5 156 psi
#6 162 psi
Interestingly, #6 has the highest reading with 162psi and #4 has the lowest at 151psi. I thought RB's where known to wear #6 the most. Maybe that's a 26 thing. Anyway 4 and 5 are the lowest, maybe due to being the 2 cylinders closest to the heat of the turbo? Someone I was chatting to recently mentioned that it's possibly due to hotspots in the water jackets of the head. Food for thought I suppose.
All the plugs looked to be burning clean. They are only 4-600km old. For some reason I took pics.
So after marveling at them for a bit,  everything was put back together and fired up. Bloody shitbox sounded like a wrx and was misfiring. It's quickly isolated to cylinder 3 using the unplug a coil at a time method. Number 3 spark plug is replaced with an old plug I had lying around and presto, all good again. I proceed to refit the misfiring one again to confirm it's the plug for sure and sure enough misfire is back, 2nd handy goes back in. #3 plug looks pristine but somehow has failed. Wasn't dropped or anything silly either, just on of those things I suppose.
My attention is now focused on giving the wastegate actuator a bit more tension. From when I recently had the turbo rebuilt, it's been making a little less boost. Was making 1.3ish bar on my gauge and now has been more like 1.2 bar. 1.5 turns is removed from the length of the actuator and followed by a test drive on the now dry Melbourne roads, unfortunately 1.5 turns was a little too much and the gauge is hitting 1.4 bar, 3rd gear roll on power slides never get old though,  I'll have to revisit it tomorrow and go back 1/2 a turn and retest😄
  • Like 2
Out of curiosity, what was the issue? As in how did they behave to get you genuinely scared?
Car felt very very unsettled over the bumpy surface and like there wouldn't be any grip because of it. If it was dry it wouldn't have been an issue. 6 year old 265 AD08R's with very little heat in them wouldn't have helped either but ultimately I feel the dampers weren't doing their job properly.
  • Like 1
  • Thanks 1
On 04/01/2023 at 10:35 PM, r32-25t said:
Most Japanese coil overs are to stiff and allow the wheels to come of the ground, once that happens there’s no grip
Sounds about right, my spring rates aren't that stiff but I believe it's the valving that is the issue here. Set up stiff for those super smooth Jap roads. I should just get rid of them but I'm too much of a tight arse. Will wait till one of them starts leaking or knocking and I've got no choice.
This would be part of the problem here, and add in thick anti roll bars (sway bars as they're often referred to) and it's a big fun mess on shit Aussie roads.
  • Like 2
Yes I do have Whiteline bars and they are set to the stiffer side of their adjustment. You've got MCA coils now don't you? What are they like on rough roads compared to whatever you had before?
They are amazing. Worth the money, th epro comfort or sports are great for daily.
My car is all brand new whiteline rubber bushes, MCA X-R coilovers, whiteline sway bars and gktech castor, toe, traction & camber arms.
Rides better than my 370z and when you hit bumps its a gentle movement where my tein superstreets went bang.
  • Like 2
I was pro thick Whiteline bars dis dat as well, on the reduce body roll brigade but have learnt through experience that thick anti roll bars aren't actually that great.
You create too many scenarios where you lift the inner wheel around turns or when you're travelling on bumpy roads both wheels on the same axle are trying to move together. Not to mention it makes the car very twitchy.
Now I'm running 10kg front springs, 7kg rear springs with the front anti roll bar set to the softest setting, and the rear set to 2nd softest setting (allows the car to clock a bit better) and I can guarantee you it is more comfy than my mates old R33 with run of the mill BC BR 8kg/6kg coil overs. Rides better than my old king spring/Bilstein setup with stupid stuff anti roll bars. Also best part, I'm no longer breaking off anti roll bar brackets at the front when I ride ripple strips.
  • Like 1
9 minutes ago, admS15 said:
When the teins expire, I know what I need to do.
Just also a friendly reminder what I refer to handling/performance might be different to you and others, very subjective in a sense 😊
I also still think my car feels like a pile shit.
  • Haha 1
Pretty much every Australian track require a softer setup to make the car fast, even our best track is no where near up to the standards of most tracks in the world or even most highways
  • Like 1
@r32-25tAll true except for Phillip Island which is pretty damn good and has to be as it's really a motorcycle track. Car feels great there.
In all honesty I think my car needs and probably deserves a better quality damper that isn't over 10 years old.
  • 1 month later...
 Not much been happening with this, a few trips to work and back and a couple of runs along my test to sort the wastegate arm adjustment to get back to 1.3 bar. Car will be going back to Trent for a couple of pulls on the dyno just to make sure all is as it should early to mid March.
Since there's not much happening with this,  may as well post about my new daily and maybe cover the daily's of the past few years.
The new current daily has been mentioned in other threads but here it is for this one.
Me the day I drove it back from Canberra in 38 degree heat.
  • Like 2
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
